I've begun working on my BOSE head unit replacement project. This video demonstrates using an Adafruit Trinket micro-controller to govern the startup and shutdown of a Raspberry Pi 3. The Raspberry Pi doesn't like to be shut down by having it's power cut (like most computers) so to use a Raspberry Pi in a car, a method for cleanly powering down is needed.
It's a first step, but a necessary one. |
Looks nice. I like the way you fit it into a factory bezel. That makes it look sharp. Off to a great start. For now it looks like a lot of hardware to fit into the dash space available. I think that is going to end up being one of the bigger problems with this idea. Where to put all of the "stuff" for that you don't have to gut and rewire your car to install the thing.
That is really nice..... :cheers:
I don't think I actually need a computer in the car BUT.... If thats what it takes to have a nice looking/sounding modern car stereo for my '88 I'm all for it. There are a lot of 1.5 DIN size radios out there and its hard to believe no one makes anything DECENT that fits. I'll be watching this thread! :thumbs: |
Originally Posted by slow-vette
(Post 1593956246)
(Post 1593956246)
I hope to make this as plug-and-play as possible. I don't want to have to rewire the car to make it work. |
Originally Posted by CCRed
(Post 1593956664)
I like it, looks like a neat idea.
I have skimmed over some options, and there really is alot out there. For the bezel, I also spent some time restoring a couple of old boats before the vette, i learned a lot about working with epoxy. I even made some molds of small items using what i could find at the time, tinfoil. :lol: Coated the inside with wax and poured the epoxy into the mold. It worked pretty good for the most part, but i think visiting a craft store that specializes in that sorta thing would make it much more reproducible. |
If it were my daily driver I wouldn't even worry about shutting it down. I am guessing it probably draws 250 to 300ma in an idle state? Not much of a drain.
Originally Posted by Silver85
(Post 1593961567)
Also, I want to minimize the possibility of data corruption by shutting the system down cleanly. |
Now if you want to be really trick design a preload and shutdown timer. For example use a relay to supply the power constant to the system. Have a tap off the courtesy light so when the door is opened the light triggers a timer to supply power and boot the system. Have the timer run for 3 minutes or so. Then have a key switched power lead to the same timer. That way the system is all booted and ready to go by the time we start the car and we won't notice the startup delay. Then have the shutdown command happen when the key switch goes off and have the timer supply power for 3 minutes after the car is shut off to allow the system to stop cleanly. I know I'm getting ahead of ourselves with this idea.
:lurk:
Are you using a 3.5 inch monitor that is capable of mirroring the image? |
Originally Posted by bill mcdonald
(Post 1593973390)
:lurk:
Are you using a 3.5 inch monitor that is capable of mirroring the image? The Raspberry Pi does have some /boot/config.txt file options that let you do a horizontal or vertical flip of the display which should render the mirror image you are looking for. |
Originally Posted by LWesthaver
(Post 1593988231)
I'm using a 5" diagonal display that is a very close match to the existing BOSE faceplate. The display doesn't support mirroring natively (from what I've discovered so far). Are you looking for a way to create a heads-up display?
The Raspberry Pi does have some /boot/config.txt file options that let you do a horizontal or vertical flip of the display which should render the mirror image you are looking for. I actually thought you figured out how to get a regular monitor to work with a PI... :rofl: I have a 3.5 monitor I picked up that has a button for mirror image. I had that working a little bit, but it is not bright enough to work in the sun light. I was figuring I would buy an arduino if you had figured out something every person on line asks about a regular monitor running PI. |
(Post 1593988561)
...I actually thought you figured out how to get a regular monitor to work with a PI... :rofl:
RCA
Video in. Composite I guess I should of said video tv, screen? I don't know. The monitor I have only has 2 rca cables. Both video in. It auto switches between sources when power is supplied somehow. I don't know as I never tested it, just what is said. So you are saying PI can be ran on a single video in, composite cable? |
Doing a search, I see it does in fact run off a single composite cable... And here I am somehow looking at searches of it saying it will not be compatible with car back up monitors. what do you know...:eek:
Guess it is time to research PI. |
It's been a few weeks since I last checked in so I wanted to post an update.
I have all of the power issues worked out now. I found an inexpensive buck-converter that can supply clean 5 volt power needed to drive the system components. The power management code running in the Trinket is finished. The Trinket enforces a set of rules such that: 1) System will not power up unless the key is in the accessory/run position. 2) System will power down gracefully when the key is removed from the ignition. 3) The system will resume if the ignition key was removed while the system was running. etc. The system only draws about 38 milliamps when idle. I'm pretty pleased with this. https://cimg4.ibsrv.net/gimg/www.cor...9876c05642.jpg I found a very small Bluetooth keyboard with touch-pad that I can keep in the center console if ever I need to use the Car-Puter like a standard PC. To web-surf etc. The keyboard is back-lit so it can be used in the dark which is a nice feature. It is also rechargeable via USB cable. https://cimg9.ibsrv.net/gimg/www.cor...687ae6d2ce.jpg I'm taking a few liberties with the faceplate layout as you can see from the paper mock-up. I want to include a USB port. The USB port can be used to supply media files (music, video etc.) to the system and also provide a way to charge your phone. Moving the display to the center of the faceplate solves a clearance issue with the USB and HDMI connectors on the display while providing a space for the USB port. https://cimg9.ibsrv.net/gimg/www.cor...01ecb84d84.jpg Here's a shot of the panel-mount USB port I will be using. I'll be mounting it with the flange behind the front panel. The mounting hardware for it and the touch-screen display will be hidden behind a black satin finish overlay (to match the rest of the car). https://cimg9.ibsrv.net/gimg/www.cor...fc8a0cfbf7.jpg I am also beginning to put together the software that will drive all of this. I suspect that the software will be the part that I spend the most time on because I'm a tweaker and can't leave well enough alone. I'm using a software development platform called "Xojo". It makes developing graphical user interfaces a lot easier than other software dev platforms available for the Raspberry Pi. I'm pretty stoked about this. I hope it proves to be a good choice. I modeled the digital clock after the original digital clock in the BOSE system right down to the size, color and segment shapes. https://cimg2.ibsrv.net/gimg/www.cor...64aaa99f42.jpg I joined a local 'Maker' group and now have access to a laser cutter. If all goes well, I'm hoping to have a chassis and faceplate fabricated in the near future. I'm planning on making the chassis out of 3mm clear acrylic (Plexiglass). This should help keep the cost down and allow for easy design changes. |
Hi,
do you know the carpi project? I was trying this out, but I couldn't get it working with a 5" Touch Display. Mine looks pretty same as yours. Unfortunately I have only experience in programming C# Apps. Will you share your software? |
It looks really cool. Keep the updates coming.
Also, are you going to try an adjust the seats from the screen? |
Originally Posted by C4Tommy
(Post 1594119664)
Hi,
do you know the carpi project? I was trying this out, but I couldn't get it working with a 5" Touch Display. Mine looks pretty same as yours. Unfortunately I have only experience in programming C# Apps. Will you share your software? Like you, I tried some of the pre-packaged setups but decided that I would rather roll-my-own so I can get exactly what I want. I'm not trying to make the on-screen interface look like today's modern stuff. I really want it to look like it could have been something from the 80's... Just more functional. I hope to share everything I'm doing. That includes CADD drawings of the chassis, parts lists and suppliers, schematics, and source code. -Wes |
(Post 1594122495)
Also, are you going to try an adjust the seats from the screen? I really like the sport seats but the controls built into the lower bolsters are prone to breaking as people get in and out of the car. I want to keep the sport seat functionality but get rid of the bolster mounted controls when I have new leather installed. Moving the controls to the touch screen is part of my plan, but low on the priority list. -Wes |
