Anyway to upgrade to the stereo interface?
I have a 15 and it does not have nav. I would like to add nav but that's not the end of the world since most people just use their phone now anyway. However I use the aux plug to play my ipod. Is there a way to use a usb cable and then the songs and info will display on the screen?
I can even do that in my 15 Grand Cherokee. Anyway to do that or any upgrades available for it? It already seems so old and out of date with the blue screen. :ack: |
I've heard mixed reviews about iPod compatibility, but you should plug it in and see. MyLink will index it, then you can use the touch screen, steering wheel controls or voice command to get to your songs. Nav is completely separate from your music.
Originally Posted by Rooster OG
(Post 1594098886)
Buy NAVtool and the GPS add-on. "Plug and Play" to get navigation on the radio screen.
Originally Posted by thegame
(Post 1594098908)
I'm so nontechnical can you elaborate on exactly what to do? So I do need to plug in through the usb port right? Then how does mylink work?
You can access all of this through the steering wheel controls or by voice command too. You should take a look at the infotainment manual, that'll walk you through getting to the various menus via the steering wheel controls or by voice. |
(Post 1594099638)
Yeah, plug it in either behind the screen or under the console lid. Then hit the media button, that will scroll you through the different media things connected to the car. If your iPod is recognized, it will be one of the choices. Once the car has indexed it, you'll be able to make selections from it by song, artist etc. if you have a lot of music on your iPod, indexing could take a while, so it might not work 100% until it's finished. If you have a few hundred songs, it might be 5 minutes, if you have thousands, it could take an hour or so.
Originally Posted by ersatz928
(Post 1594099540)
edit - found there are 2 more in the middle console. I will play with this on the weekend. |
You can upgrade the HMI module to get new functionality. I think the 2016 HMI module is backward compatible with the 2014 and 2015 cars.
The 2016 has CarPlay and Android Auto if it's running the latest 2016 SW. Besides that any MyLink system should be able to get music off of an iDevice by Bluetooth or USB cable. |
(Post 1594098886)
(Post 1594098846)
I can even do that in my 15 Grand Cherokee. Anyway to do that or any upgrades available for it? It already seems so old and out of date with the blue screen. :ack: Ebay good source for the Nav module etc. Hope that helps. |
Originally Posted by gunnerja
(Post 1594114227)
My understanding you can change out the unit above drivers feet and put the antenna in the speaker cover and add nav for $850.00. (I looked hard as before buying my Z06 was not looking for PDR). However all the investigation I did, you can't update the Apple Carplay without changing out the main unit.
Originally Posted by LT1 Z51
(Post 1594104996)
Here you go:
http://www.infotainment.com/products...-radio-upgrade You can add CarPlay/Android Auto for extra. |
(Post 1594114408)
Here you go:
I have no idea, I haven't done that one. This guy did, I didn't read his whole thread though:
https://www.corvetteforum.com/forums...l-for-nav.html |
ok i will check it out thanks for the help
