Matching Combo: Cam, PSI Springs, Ferrera Valves, BTR Push Rods, LS7 Lifters
SOLD!
Cam is a Comp LSL lobed with 19* Overlap, made 599RW on a conservative dyno and trapped 136.xx MPH in San Antonio TX summer heat! Springs are PSI1515ML, and valves are Ferrera F2042P Hollow Stems. The PR are BTR .080 wall and 7.750" long (.030 mill LS7 head). Lifters are LS7. All under 5000 miles. Why selling? I'm swapping to more cam/VT so they need to be gone. With a clean tune cam is very, very streetable. Explosive throttle response and pulls like a freight train! Easy over $1100.00 in value... Here is a sound clip of the "cam": Let me know! :cheers: |
PM'd
If still available would it be compatible with 07 base ls2?
Originally Posted by jorgep951
(Post 1594247162)
The cam and lifters will be but unfortunately the springs and valves may not. The recommended install height of the PSI LS1515ML spring is 1.950" to support the longer valve of the LS7, where it would be too long for the shorter valve on the LS2. |
Pending Sale! :thumbs:
Sold!!
