Is soem of this cam emission leagal?
I have a stock Ls2 ttix on e85 is anyone of this cam going to pass emission?
227/231 | .625"/.605" | LSA114+4 228/235 .605/.609 116+5 |
Define "pass emission". What tests are required in your area?
CO Max 0.5
CO 2500 rpm 0.3 HC max 100 Lambda 0.96-1.25 |
bump
If you don't have to measure emissions at idle (but at 2500...3000 rpm), it will be ok, assuming your tuner knows how to tune GM PCM's.
CO Max 0.5 and HC max 100 is at idle is this possible?
I'm hardly a camshaft expert, but I am pretty familiar with passing a smog test.
Without the cats, either are likely to fail. With properly functioning cats and a reasonable tune, the second one seems likely. My reading of the specs say wide LSA=low overlap=fairly clean on the HC. It compares pretty closely to my 224/236 .649/.649 on 117+4. 2 local tuners said "why, that's smaller than my smog cam!" (California smog) |
Originally Posted by n_brio
(Post 1594324784)
Even with a very mild cam and no cats, that would be doable. But go too far with the cam and even with cats that will be difficult. That said...both of those cams are probably pushing things a bit, and would most certainly need cats to have any chance of passing. |
Takes a pretty fresh engine and careful map to idle below 1/2%CO and still be smooth enough to read below 100ppm HC, even with a factory stock cam. Raising the idle helps a bunch!
With good cats and not a bunch of overlap, should read pretty close to 0 on both, but doesn't take much 'misfire' to overpower the cats and spike the HC. NOx is the tough one... but doesn't sound like it's tested there. Lucky bastard! |
we dont messur NOx here in sweden =)
Is it possible to have a cam that passes my emissions with out cats an the car? im on e85.
Someone please correct me if I'm wrong with this.... but .5%CO is right at stoich?
Too much leaner than that will make the HC rise ("lean misfire"), so needing to be leaner than that to pass CO will elevate the HC... and 100ppm at idle without a cat is already pretty tough. It's going to be a pretty fine dance on the mapping! I think I'd pass on that challenge. |
it's not quite as straightforward as that...but 0.1% CO on paper is around 14.7:1 AFR gasoline
0.5% would be around 14.3:1 But that would be with a proper gas analyser, a lambda sensor may not always match Havent a clue about E85 though and how it performs |
Working from memory, all the O2 sensor cars wanted to hover right around the .5% mark pre-cat. But it's been a long time since we needed to make those routine adjustments!
It would be a fun challenge to see just how clean you could make this one... but I don't think clean enough. Theoretically, E85 will help with the HC, but zero first hand experience. |
