Gates RPM belt
Has anyone tried the Gates RPM belt? Did you like it?
Originally Posted by Ls2gtoowner
(Post 1594320156)
I would like to know as well. Subscribed for updates. |
I used one and it worked great. They stretch ZERO from new once you put them on which is nice and made a touch more boost at redline because they are a little more sticky than the green belts. The only size they made that was close to fitting my car ended up being a touch too long so had to move to a slightly smaller belt unfortunately which is not made in RPM size. I was hoping it would work on my car and if they had the 915 size my car takes i'd use it for sure.
Originally Posted by jeolesen
(Post 1594876258)
Originally Posted by neverstop
(Post 1594876800)
I just installed mine last week. No stretch, no squeaks even at 20psi from a ysi
Originally Posted by C5Natie
(Post 1594879968)
(Post 1594882621)
Where did you get it??
o'reily etc didn't and couldn't get them anywhere in my area. The guy who does griptec stocks them but I just called around and found a local parts distributor who special ordered mine. was expensive though, like $90
(Post 1594886981)
https://www.gates.com/~/media/files/...list-lores.pdf For example, here is my belt http://www.oreillyauto.com/site/c/de...ord=k080530rpm |
they work well, I am starting to stock some of the common sizes.
Originally Posted by Joe@CPR
(Post 1594907290)
I tried that at multiple O'reillys with zero success. their employees are idiots. faster and easier imo to just order from someone like CPR here who knows what they are doing. have heard stories of people "special ordering" RPM belts from oreily only to show up and find a gates green belt.
Looks like RockAuto has some of the RPM belts.
K060888RPM is $49 |
interesting. 888 is not on gates list. did you get it?
hm, 882 is even $10 less. i thought they were expensive. |
i got a rpm belt 5 mm longer that the belt i had. when installed its a little shorter than the old belt, reducing wrap. the pulley is about 15 mm lower now. ill be trying the next size, as soon as i order from them again.
I'd like to give one a try, never cared much for the green HD belt anyways.
Problem is I can't find K100529RPM. Gates makes it but can't find one stocked anywhere must be too new... If someone runs across that size let me know |
1 Attachment(s)
Originally Posted by Mike04
(Post 1595105624)
Problem is I can't find K100529RPM. Gates makes it but can't find one stocked anywhere must be too new... If someone runs across that size let me know We really like the new RPM belts and have started stocking up on those as the new first choice in the sizes available. Attachment 48112956 |
now, that i installed the rpm belt it occured to me that maybe its harder on the blower, because its less flexible. any thoughts?
Originally Posted by romandian
(Post 1595135155)
