Issues the ECS kit with Innovative West 10% Overdrive Balancer
I have had my Novi 2000 kit for quite some time (and I love it) but was wondering if others have seen the same situation I have. The tensioner makes contact with the balancer when the belt is not in place obviously because it is larger than the stock damper. I guess I really didn't care until last year when the bearing failed on the tensioner, thus destroying the belt, then plunging the tensioner into the balancer, causing damage to the balancer.
I am also direct driving the blower on the setup (I use a flip drive for everything else) and have issues withe the Green Stripe belt sizing. With a 3in blower pulley i am stuck using a K08525HD because the K08514HD belt is impossible to get on. I even tried removing the blower to get the small belt to fit. IMO the larger belt seams a tad bit loose even with the manual tensioner maxed out. I am thinking about solving my belt length issue (being too long is not good) and my tensioner/balancer issue by relocating the tensioner. Has anyone had similar experiences or have a better solution? |
The tensioner bracket next to the balancer could be modified so the tensioner does not make contact. You simply need to drill a hole further to the left to prevent the tensioner from bottoming out or just call ECS to send you one. The kit you have was designed for a stock size balancer unless you specifically mentioned the 8" balancer.
As for the belt, 3" pulley with 8" balancer works with a 525 belt. I managed to get a 514 belt on...not easy, but can be done. Most power I made was with the 514 belt. |
Here is the bracket you need, just make sure that your tensioner has two dowel pins. Our older tensioners did not, that was years ago but I don't know how old your kit is.
http://www.eastcoastsupercharging.co...ategory_id=331 |
Originally Posted by DOUG @ ECS
(Post 1594350489)
Ended up busting out a new bracket today. Ended up looking like this.
http://i1227.photobucket.com/albums/...psof13qhp8.jpg |
