Rear brake piston wont retract into caliper
I dont know what I did but I was putting the brakes back on and the piston was pushed out like I had it the brakes. Ok no big deal get my brake set to push it back in and nothing it wont budge back into place...Hmmm ok odd but let me get more leverage and hold it in the vice while I turn the handle on the brake tool..Again nothing...Ok so I take a pipe slip it onto the handle on the brake tool and put my back into it....Nothing I'm bending the damn handle on the brake tool..Ok now let me put it in the jaws of the vice grips..Crank it down and the whole bench is lifting up and still it doesn't budge..WTF happened?
Originally Posted by Chicago1
(Post 1594407975)
Originally Posted by SG Lou
(Post 1594408272)
Classic example of a seized caliper.....time for a rebuild or replacement.
How did it get seized though? Anyone know where to get the rebuilt or just buy a used one for like 60 bucks? Also since I have it completely when I go to put the new one it do I need a tech 2 to bleed the brakes?
(Post 1594411271)
As for a Tech 2 ? It wouldn't hurt to bleed the brakes with it but i have done it on my Silverado without it......... |
(Post 1594411367)
You can buy new, re-manufactured or used the choice is up to you.
I had this same thing happen to me the other week. Before you run out and get new caliper take a look at the piston coming out of the caliper. Mine was at a slight angle. Tried to compress with no success. I re alligned the piston in the caliper and it went back in. Try gently tapping on the side of the piston to get it to shift.
^ yes it is at a angle...exactly like you just described. Did you hit it with a hammer or take it out? shoot me a pm with your number
If your going to do it that way use a brass hammer so you don't damage the piston
Got it compressed or Tcruse got it but I think I am going to buy a new one. I think I messed it up before he was able to get it compressed.
(Post 1594437895)
Originally Posted by helga203
(Post 1594438205)
Sorry off topic. You Ever get your over heating fuel problem solved??
We shall see this week. Car has been down over a year beacuse I bought a Jeep Wrangler so that took the focus off. I did put new tanks in and crossover tube, ls7 maf,80lbs..So we shall see if not I'll be taking it to a shop. Wish me luck.:cheers: |
(Post 1594439164)
Originally Posted by Smoken1
(Post 1594418239)
When Chicago1 asked if he hit it with a hammer thats why I suggested a brass hammer and not a regular hammer.
finally got the car running after 1.5 years gots no brakes now they need to be bled but I just bought a new one.Now just need my tech 2
