Wipers refuse to work properly
I hate to beg for help, but I'm at the end of my rope. I recently acquired a 1988 'Vette that had been garaged most of its life. I'm in the process of restoring it, but one issue I absolutely cannot solve are the wipers. The wipers only activate at the top setting on the switch, and then they barely move, raising up about an inch before going back down repeatedly. I replaced the transmission, motor, motor cover/board, and nothing is physically blocking any mechanical components. I have no idea what could be causing this. I don't know for sure if the switch would cause this or not, and I'd like to know for sure before I burn more money on these things.
Has anyone ever experienced this issue before? |
Originally Posted by Van0079
(Post 1594503461)
Originally Posted by alexm1994
(Post 1594503840)
That's all that's left, replace the switch.
About the only other thing you could try prior to doing the switch is lift the hood and see if it now works or not. Not likely but it's possible something is hanging up somewhere you're not seeing. |
(Post 1594503461)
Has anyone ever experienced this issue before? Yes the wiper switch can go crazy with uneven sideways pressure on the knob. If no one has posted the wiper motor diagnostic info will do it tonight. :thumbs: |
You may have to clean the connectors on the switch and spray cleaner inside. My wipers worked like that but after a few cleans of the switch and socket they now are working perfect for a year now. Im talking sandpapering and putting some dielectric grease.
Originally Posted by gerardvg
(Post 1594509331)
The wiper motor cover has a plastic part that needs to be fitted correctly, am at work not near my shop manual hopefully someone will post how to correctly align that plastic part in the cover.
Yes the wiper switch can go crazy with uneven sideways pressure on the knob. If no one has posted the wiper motor diagnostic info will do it tonight. :thumbs: I'll try cleaning the connections when my new switch comes in. |
1 Attachment(s)
So my new switch came in... and it's not compatible. Despite being marketed to 87-89 models, when I removed my door panel the ground terminal in my car was completely different from what the replacement had, and I couldn't put it in at all. :banghead:
Does anyone know at all where I can find the proper type? Why has nobody ever mentioned this difference anywhere? I attached an image of the terminals, although my phone makes potato-quality pictures. The wrong ground terminal is the big one to the right, as you can see it doesn't match the other two smaller terminals in the slightest. |
Can you take a pic of the switch ,the green wire looks like the one on my 85.
Had the same problem with my '89. The wipers would only work on the highest setting. No low or intermittent speeds. I replaced the switch. The new switch I ordered was also incorrect. I had to cut the end off of the old switch and splice onto the new switch using a crimp on butt connector. It did the trick. I now have wipers with all speeds.
1 Attachment(s)
Originally Posted by xrav22
(Post 1594534484)
(Post 1594537081)
Here's a pic of the replacement, I'm not getting open the door again for the original. However, after looking at around, I noticed that the switches marketed at 84-85 C4s have the correct connector, so I've ordered one and I'm hoping that the stock photography of them matches the item and has the right terminal. Did GM selectively use older components in newer C4s or something? I can't fathom why my 88 would have this instead of the newer.
That looks like the connector in my 85, you could just splice your connector to get it going if you cannot wait? I believe it is for the light in the wiper switch from memory. Here is some info that might help, has wiring diagram also. Is from my 85 shop manual. The 88 should not be too much different. http://i1230.photobucket.com/albums/...psnkfl1nk8.jpg http://i1230.photobucket.com/albums/...psr1quvefn.jpg http://i1230.photobucket.com/albums/...psvfgb4m8p.jpg http://i1230.photobucket.com/albums/...psr44z9cqw.jpg |
1 Attachment(s)
New switch came in and I installed it... only for the problems to persist. Only activated on highest setting, and the wipers barely moved at all. I don't fucking get it. Is there a piece missing?
Just checking but did you sandpaper the metal contacts(if reusing) and spray electric cleaner into the plug because they are sensitive(in the door switch)then put clear dielectric grease into the plug to continue weatherizing. Once you get them running you need to run them pouring water on the windshield. There is a plug beneath the motor it would probably need a cleaning too ensuring pproper eclectric voltage mine was dirty.
Good Luck |
Hi
You must be pulling your hair out now... Check the connections as mentioned by xrav22. Check the wiring connections to the delay circuit (wiper motor cover) And wiper motor itself. See link to Eckler's wiper motor and delay circuit https://www.ecklers.com/corvette/cor...-106734-1.html https://www.ecklers.com/corvette/cor...-108640-1.html |
feel ur pain. i agree with previous couple of posts. focus in on checking for massive resistance areas. sounds like voltage is being sapped and only when u give it the full theottle does it get through and when it does its not much resulting in a slow wiper.
Maybe
This IS happening to me, today, right now.
(Post 1594503461)
(Post 1594509331)
Who would have thunk that? :cheers: |
My car had that problem when I went and looked at it. If I remember correctly the previous owner had to replace the wiper motor cover. There is a circuit board in it that has to do with the switch. It was hard to find and cost him about $100.
I made a video in the hopes that somebody might be able to figure it out.
