C4 Interior Restoration Parts At RPI Designs
1984-1988 C4 Corvette Seat Foam
If you are replacing the seat covers in your 1984-1988 C4 Corvette you should replace the seat foam at the same time. Replacing your worn out seat foam will make your new seat covers look and fit like new. Our reproduction C4 Corvette seat foam is correctly formed and includes pre-installed wire supports where applicable. These C4 Corvette seat foam kits are made by Corvette America in Reedsville Pennsylvania. 1984-1988 C4 Corvette Sport Back Seat Foam $84.54 With Code PHIL5 At Checkout https://cimg5.ibsrv.net/gimg/www.cor...9f303471ac.jpg https://www.rpidesigns.com/shop/item...ack-seat-foam/ 1984-1988 C4 Corvette Sport Seat Foam Bottom $84.54 With Code PHIL5 At Checkout https://cimg3.ibsrv.net/gimg/www.cor...750aef0dc8.jpg https://www.rpidesigns.com/shop/item...t-foam-bottom/ 1984-1988 C4 Corvette Sport Seat Foam 4 Piece Set $312.54 With Code PHIL5 At Checkout https://cimg7.ibsrv.net/gimg/www.cor...f9c209dd6d.jpg https://www.rpidesigns.com/shop/item...m-4-piece-set/ 1984-1988 C4 Corvette Standard Seat Foam Back $79.79 With Code PHIL5 At Checkout https://cimg4.ibsrv.net/gimg/www.cor...bf38cdab4c.jpg https://www.rpidesigns.com/shop/item...eat-foam-back/ 1984-1988 C4 Corvette Standard Seat Foam Bottom $79.79 With Code PHIL5 At Checkout https://cimg6.ibsrv.net/gimg/www.cor...1e0619820b.jpg https://www.rpidesigns.com/shop/item...t-foam-bottom/ 1984-1988 C4 Corvette Standard Seat Foam Bottom $293.54 With Code PHIL5 At Checkout https://cimg9.ibsrv.net/gimg/www.cor...e0143efd24.jpg https://www.rpidesigns.com/shop/item...m-4-piece-kit/ |
1989-1993 C4 Corvette Seat Foam
If you are replacing the seat covers in your 1989-1993 C4 Corvette you should replace the seat foam at the same time. Replacing your worn out seat foam will make your new seat covers look and fit like new. Our reproduction C4 Corvette seat foam is correctly formed and includes pre-installed wire supports where applicable. These C4 Corvette seat foam kits are made by Corvette America in Reedsville Pennsylvania.
1989-1993 C4 Corvette Sport Seat Foam Bottom $84.54 With Code PHIL5 At Checkout https://cimg6.ibsrv.net/gimg/www.cor...1cf9f2af44.jpg https://www.rpidesigns.com/shop/item...t-foam-bottom/ 1989-1993 C4 Corvette Sport Seat Foam Back $84.54 With Code PHIL5 At Checkout https://cimg8.ibsrv.net/gimg/www.cor...e7fe63e0d6.jpg https://www.rpidesigns.com/shop/item...eat-foam-back/ 1989-1990 C4 Corvette Sport Seat Foam 4 Piece Set $312.54 With Code PHIL5 At Checkout https://cimg2.ibsrv.net/gimg/www.cor...dc8d44f923.jpg https://www.rpidesigns.com/shop/item...m-4-piece-set/ 1989-1993 C4 Corvette Standard Seat Foam Bottom $79.79 With Code PHIL5 At Checkout https://cimg2.ibsrv.net/gimg/www.cor...dd5b3aab76.jpg https://www.rpidesigns.com/shop/item...t-foam-bottom/ 1989-1993 C4 Corvette Standard Seat Foam Back $79.79 With Code PHIL5 At Checkout https://cimg4.ibsrv.net/gimg/www.cor...9c19936756.jpg https://www.rpidesigns.com/shop/item...eat-foam-back/ 1989-1993 C4 Corvette Standard Seat Foam 4 Piece Kit $293.54 With Code PHIL5 At Checkout https://cimg8.ibsrv.net/gimg/www.cor...c093463748.jpg https://www.rpidesigns.com/shop/item...m-4-piece-kit/ |
1991-1993 C4 Corvette Sport Seat Foam Bottom Driver Side
When replacing the bottom seat foam in your 1989-1993 C4 Corvette be sure to replace it with the correct style. From 1989-1993 Corvette had left and right side lower seat foam. Our reproduction C4 Corvette seat foam is correctly formed and includes pre-installed wire supports where applicable. These C4 Corvette seat foam kits are made by Corvette America in Reedsville Pennsylvania.
1991-1993 C4 Corvette Sport Seat Foam Bottom Driver Side $84.54 With Code Phil5 At Checkout https://cimg0.ibsrv.net/gimg/www.cor...64a95be29c.jpg https://www.rpidesigns.com/shop/item...m-driver-side/ 1991-1993 C4 Corvette Sport Seat Foam Bottom Passenger Side $84.54 With Code Phil5 At Checkout https://cimg6.ibsrv.net/gimg/www.cor...3558603912.jpg https://www.rpidesigns.com/shop/item...assenger-side/ 1991-1993 C4 Corvette Sport Seat Foam 8 Piece Set $312.54 With Code Phil5 At Checkout https://cimg7.ibsrv.net/gimg/www.cor...b064b04453.jpg https://www.rpidesigns.com/shop/item...m-8-piece-set/ |
1994-1996 C4 Corvette Standard Seat Foam
Installing new seat foam in your C4 Corvette will make your seats feel like new again. Also if you are installing new seat covers now is the perfect time to replace your worn original seat foam. Our reproduction C4 Corvette seat foam is correctly formed and includes pre-installed wire supports where applicable. These C4 Corvette seat foam kits are made by Corvette America in Reedsville Pennsylvania.
1994-1996 C4 Corvette Standard Seat Foam Bottom $79.79 With Code PHIL5 At Checkout https://cimg9.ibsrv.net/gimg/www.cor...9b55fd9451.jpg https://www.rpidesigns.com/shop/item...t-foam-bottom/ 1994-1996 C4 Corvette Standard Seat Foam Back $79.79 With Code PHIL5 At Checkout https://cimg6.ibsrv.net/gimg/www.cor...e51f84cd9c.jpg https://www.rpidesigns.com/shop/item...eat-foam-back/ 1994-1996 C4 Corvette Standard Seat Foam 4 Piece Kit $293.54 With Code PHIL5 At Checkout https://cimg7.ibsrv.net/gimg/www.cor...6c609ee3a0.jpg https://www.rpidesigns.com/shop/item...m-4-piece-kit/ |
Seat foam
Do you do seat covers as well ??
Thanks Fred |
Originally Posted by fredk
(Post 1594527388)
Thanks Fred I am working on getting things loaded and have not got them on our website yet. Let me know what you are looking for and I can get you a price. Phil |
C4 Corvette Convertible Lock Pillar Trim
1986-1996 C4 Corvette Convertible Lock Pillar Trim $46.55 With Code PHIL5 At Checkout.
Keep the interior of your C4 Corvette looking like new with our C4 Corvette 1986-1996 Convertible Upper Lock Pillar Trim Plates.These Corvette Convertible Upper Lock Pillar Trim Plates are reproductions of the originals. Available in unpainted plastic, these Corvette Convertible Upper Lock Pillar Trim Plates are durable and look amazing on your Corvette. Sold in Pair 1986-1987 C4 Corvette Convertible Lock Pillar Trim $46.55 With Code PHIL5 At Checkout. https://cimg3.ibsrv.net/gimg/www.cor...6eb6ee5f6e.jpg https://www.rpidesigns.com/shop/item...k-pillar-trim/ 1988-1989 C4 Corvette Convertible Lock Pillar Trim $46.55 With Code PHIL5 At Checkout. https://cimg5.ibsrv.net/gimg/www.cor...71b989b6ad.jpg https://www.rpidesigns.com/shop/item...k-pillar-trim/ 1990-1993 C4 Corvette Convertible Lock Pillar Trim $46.55 With Code PHIL5 At Checkout. https://cimg9.ibsrv.net/gimg/www.cor...26c7e894d1.jpg https://www.rpidesigns.com/shop/item...k-pillar-trim/ 1994-1996 C4 Corvette Convertible Lock Pillar Trim $46.55 With Code PHIL5 At Checkout. https://cimg1.ibsrv.net/gimg/www.cor...805f6ef1b4.jpg https://www.rpidesigns.com/shop/item...k-pillar-trim/ |
Hi Phil
1993 grey sport seat covers with 40th stitching mounted. Thanks Fred |
(Post 1594553753)
Hi Phil
1984-1989 C4 Corvette Interior Standard Door Panels
1984-1989 C4 Corvette Interior Standard Door Panels $512.99 Wit Code PHIL5 At Checkout
Replacing the worn out and faded door panels on your 1984-1989 C4 Corvette is a great first step to returning your car to a like new condition. Our replacement door panels are made in the USA and will be a perfect fit and finish to properly restore your C4 Corvette. Feature Carpet Strip, Inner Window Seal, and Lower Air Vent. Simply transfer your Armrest, Upper Door Trim, and Upper Air Vent. OE Reproduction Fits 1984-1989 Corvettes Installation Instructions Included 1984-1989 C4 Corvette Interior Standard Door Panels Black https://cimg0.ibsrv.net/gimg/www.cor...09ab36d84d.jpg https://www.rpidesigns.com/shop/item...-panels-black/ 1984-1987 C4 Corvette Interior Standard Door Panels Graphite https://cimg4.ibsrv.net/gimg/www.cor...260c8d278a.jpg https://www.rpidesigns.com/shop/item...nels-graphite/ 1984-1985 C4 Corvette Interior Standard Door Panels Red https://cimg6.ibsrv.net/gimg/www.cor...6a02f5b658.jpg https://www.rpidesigns.com/shop/item...or-panels-red/ 1984-1987 C4 Corvette Interior Standard Door Panels Gray https://cimg0.ibsrv.net/gimg/www.cor...770ebd099a.jpg https://www.rpidesigns.com/shop/item...r-panels-gray/ 1984-1985 C4 Corvette Interior Standard Door Panels Blue https://cimg3.ibsrv.net/gimg/www.cor...75954c1483.jpg https://www.rpidesigns.com/shop/item...r-panels-blue/ 1984-1987 C4 Corvette Interior Standard Door Panels Bronze https://cimg8.ibsrv.net/gimg/www.cor...1b90b91fad.jpg https://www.rpidesigns.com/shop/item...panels-bronze/ 1984-1987 C4 Corvette Interior Standard Door Panels Saddle https://cimg6.ibsrv.net/gimg/www.cor...281de49970.jpg https://www.rpidesigns.com/shop/item...panels-saddle/ 1986-1989 C4 Corvette Interior Standard Door Panels Blue https://cimg9.ibsrv.net/gimg/www.cor...9dfbf6fe7a.jpg https://www.rpidesigns.com/shop/item...r-panels-blue/ 1986-1989 C4 Corvette Interior Standard Door Panels Red https://cimg3.ibsrv.net/gimg/www.cor...df84d2c78e.jpg https://www.rpidesigns.com/shop/item...or-panels-red/ 1988 C4 Corvette Anniversary Edition Door Panels https://cimg9.ibsrv.net/gimg/www.cor...f0692e522d.jpg https://www.rpidesigns.com/shop/item...n-door-panels/ 1988-1989 C4 Corvette Interior Standard Door Panels Saddle https://cimg3.ibsrv.net/gimg/www.cor...66d0fb1ddd.jpg https://www.rpidesigns.com/shop/item...panels-saddle/ |
91 seat covers in black sport?
Originally Posted by G8nightman
(Post 1594820758)
Let me know if you are interested. I just have not had time to load them on our website yet. |
Any pictures?
(Post 1594897248)
Any pictures?
https://cimg3.ibsrv.net/gimg/www.cor...225b26749d.jpg |
Will the seat say corvette on them? Also Mine is a ZR1 and it has seat controls on both sides of the bottom of the seat.
(Post 1594902650)
C4 corvette Seat Accessories
1984-1993 C4 Corvette Right Hand Seat Control Bezel $9.49 With Code PHIL5 At Checkout
The seat controls on your C4 Corvette take a lot of abuse. From the sun fading them out to sliding in and out of your seats something is always damaging them. Our reproduction seat control bezels will restore the new car look to your car. https://cimg2.ibsrv.net/gimg/www.cor...60d8f648be.jpg https://www.rpidesigns.com/shop/item...control-bezel/ 1984-1993 C4 Corvette Left Hand Seat Control Bezel $9.49 With Code PHIL5 At Checkout https://cimg9.ibsrv.net/gimg/www.cor...8918b0850a.jpg https://www.rpidesigns.com/shop/item...control-bezel/ 1984-1996 C4 Corvette Seat Transmission $139.64 With Code PHIL5 At Checkout If your seat has stopped working then you will need to change out your seat transmission. Our C4 seat transmissions are available with small gear and large gear. Please select your choice below. These are the same for left and right seats. These are very nice 1984-1996 C4 seat transmissions. https://cimg1.ibsrv.net/gimg/www.cor...a8d2ba93bc.jpg https://www.rpidesigns.com/shop/item...t-transmision/ 1984-1996 Corvette Seat Bottom Cushion Support Trapeze Repair Kit $24.50 With Code PHIL5 At Checkout If the seats in your C4 Corvette are not as comfortable as they once were then you may need our 1984-1996 Corvette Seat Bottom Cushion Support Trapeze Repair Kit. This kit will replace the worn out trapeze that holds your seat bottom up. Giving you a much more comfortable ride. https://cimg5.ibsrv.net/gimg/www.cor...7cfabe2b95.jpg https://www.rpidesigns.com/shop/item...ze-repair-kit/ |
:thumbs:
1984-1996 C4 Corvette Transparent Targa Top Sun Shade Blackout
1984-1996 C4 Corvette Transparent Targa Top Sun Shade Blackout $56.99 With Code PHIL5 At Checkout
Do you love your C4 glass top but hate baking in the sun? We've got the fix for you. This sun shade blackout is made of a heavy fabric with a plastic backing as seen. Simply snaps into place with plastic tabs built into the liner for a sun shield that'll keep you cool! This is not one of those cheap vinyl blackouts. This is a heavy-duty, fabric and plastic blackout panel. Very nice quality piece. Fitment: 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996 C4 Corvette w/Glass Top https://cimg6.ibsrv.net/gimg/www.cor...62dfd58d2a.jpg https://cimg0.ibsrv.net/gimg/www.cor...00ff445d65.jpg |
