Washing your Z06
What methods of washing are you guys using for your cars? I live in southwest Las Vegas where our water is VERY hard. I've owned my Z06 for 2.5 months and have not washed it at my house yet because I know the water will cause very bad water spots all over the car. You should see what the water does to our sinks and toilets.
I found a really good mobile detail company and used them with great results but I'd prefer not to spend $60 every time to have someone come out to my house. I actually enjoy washing my cars but won't wash the Z06 with my hard water. What are some options available? Do any of you take your cars to hand wash only car washes? I won't use the automatic car washes that use those big brushes because I feel that will damage the paint. Any products I can buy that use no water or clean up the water some how? |
buy a water deionizer for your house. only use it to wash your car. problem solved
i used to be a die hard ONR fan, then i learned about Wolfgang rinseless car wash... i have to say i like it better. two buckets of water, a slew of microfiber towels and some cold beer is all you need
edit - and most of the rinseless stuff has water softening agents in it http://www.detailedimage.com/Ask-a-P...inseless-wash/ |
Why not invest in a water softener or filtration system? There are some water free cleaning supplies but i wouldn't used them if the car is really dirty. I use lucas speed wax for touching up but use chemical guys foam gun with a pressure washer to was my cars.
if mine is nasty dirty, i take it to the car wash and spray it off then go hand wash it.... been doing this for 2 years on this car, and 2+ years on last car that was black.... never received any wash related scratches
I use CR spotless if it's really dirty or caked with bugs. if it's just dust I use quick detailer.
Adams rinseless wash works amazingly well.
My car probably see a full wet wash 2 times a year. Other than that Adams maybe every 6 weeks for a rinseless wipe down. You can buy a system to remove the minerals from the rinse, or just dry the car in a timely manner. Hard water isn't bad to remove if it did build up. A quick buff takes it out quickly enough. |
A good friend uses one of these: https://www.samsclub.com/sams/cr-spo...17=1o3&veh=sem
I personally just don't let water dry on the surface. Always wash in the shade and keep the car wet until it's time to dry. :thumbs: |
Don't use city water. Or a hose for that matter. I use OMR No Rinse car wash. Two buckets of water, a mitt, and a towel. Works great. You use almost no water, you can buy water or use filtered water so you never have to worry about it being hard, and you get great results, and it's super fast. Here's my video:
OMR No Rinse: |
Originally Posted by Must_Have_Z
(Post 1594564117)
OMR No Rinse: https://www.amazon.com/Optimum-NR201.../dp/B00D8DR0AO |
Originally Posted by Unreal
(Post 1594564028)
My car probably see a full wet wash 2 times a year. Other than that Adams maybe every 6 weeks for a rinseless wipe down. Yu can buy a system to remove the minerals from the rinse, or just dry the car in a timely manner. Hard water isn't bad to remove if it did build up. A quick buff takes it out quickly enough. Watch his videos on YouTube or on his website and you'll be getting complements everywhere you go. |
I'm not sure about the hard water issues, but try to not touch your car unless you have to. Even with a good two bucket method, you will get swirls. I'm really liking my foam cannon followed by a good rinse and blow dry at home. I do have to hand wash bugs off the front a bit and I use wheel brushes to get all the brake dust off. If I want it looking extra good I'll use quick detailer and a microfiber afterwards.
For the interior just to use only water as much as possible. I see a lot of interiors that have been ruined by greasy armor all type products. That was a big deterrent for me when I was looking to buy a used Z06. |
Look up "Gary Dean Wash Method". He has some good videos on explaining rinseless wash style car cleaning.
So, I live in Washington, where it rains all the time. I have set up a rainwater catchment system where I have 2200 gallons of rainwater at my disposal. Rainwater is soft, no minerals. Awesome for washing a car. I use a pressure washer to rinse off the bugs and whatnot, then foam cannon, then rinse with the pressure washer. Then, I get out my Stihl blower and blow dry. The key is to not touch the car. That way you don't get spider webs.
I take mine to River Bend car wash in Yorba Linda CA. Best car wash in So Cal. These guys take their time, wash it by hand as opposed to running it through the system and pay attention to detail. Between washes I take my California car duster to it. Rick
Originally Posted by Tech
(Post 1594564114)
Originally Posted by fattiremike
(Post 1594567055)
No Water
I do not use any water to clean my vettes, I use Adams waterless car cleaner and their detail spray, sometimes Meguiars products. I keep the engine bay and undercarriage clean with various products by hand, with no water and no pressure cleaning.
Buy a cheap water softener for the house, you can wash your cars plus it will fix the toilets, sinks, tub and shower.
Originally Posted by DanMan35
(Post 1594567612)
How do you get the dirt and grime off the car if you don't touch it? I'm trying to imagine this. If you have some bad road grime or dirt on the paint of the car. And you spray it with soap and then rinse it off, how are you getting all the dirt off if you aren't actually wiping it off?
