2 Attachment(s)
Originally Posted by FINWOLF
(Post 1594585153)
very nice car any pic's of the front. I like the pin strip.
Here you go..Thanks! |
Originally Posted by Big Hit
(Post 1594595175)
I am not a fan of the 6 tail lights, however I wouldn't mine them if they had a sequential blinking turn signal kit.
I have several questions if you dont mind. I recently purchased a 1964 corvette sr coupe. Factory everything numbers matching. I plan on doing a resto mod sr111 frame mayne in about 15 months. But i wanna work with what i have now. My issue is there are not many wheels out here to fit factory frame. Is it possible to get c5 wheels on what is required to change to get those wheels to fit? Can i keep factory frame? Can i put those wheels on my 64 with no problem. I am planning on doing the larger quarters this upcoming week. I was thinking of 1.5 inch wider from ecklers. What size was on the 63 you had..... Bottom line i am trying to confirm what must i do to fit those wheels. I believe c5 wheels they are front 17x8.5 and rears 18x9
Fender flares are the answer to larger tires and wheels as that was the purpose back in the day You will be limited by your drum brake but f you change to disc you will not have any problems with other wheels.
c5 wheels
Originally Posted by 68hemi
(Post 1594601050)
also i was reading. what does it mean when said to have . "off set trailing arms onthe back". ? thanks in advance tony
