C4 Targa Soft Top lightweight and folding
New member as of April 22 , 2017
The Designer This forum never ceases to amaze me with the information and knowledge " Not Google Junk that you have to sift through " I love Corvettes . Through the years I have had 1975 Coupe "T-Top" . Tops were pretty easy to install. 1985 Coupe "20 years ago top was heavy, but I could put it on alone. Now Retired "Aerospace engineer/designer " and much older, I needed a project to keep me busy and out of my wife's hair. Recently purchased again a 1985 coupe "Barn Find" without a Targa top. Found a top on craigslist and realized I can't put it on alone. I looked for soft tops on the Internet but couldn't find anything that would serve my purpose. So I decided to design my own " In the new member section I quoted, as a joke, " how hard could it be ??!! " This is why I found your discussion on the C4 targa tops very informative. Never understood these 8 mm bolts? Where are the latches ? I just ASSumed the C4 Coupe would be on a convertible chassis. Knowing the problem of Vibration Existed , and still manufactured them?? Back to my original post in the new member section, I am designing and manufacturing a personal " light weight , folding convertible top " Will now be a lot stronger. Many Thanks to the CF members. The Designer |
Originally Posted by The Designer
(Post 1594610763)
I own such a top. The foldable top is from Vettop called a Day-Tripper. Purchased in 1998. It folds in half, has convertible top fabric and bolts to the existing C4 top locations, and has OEM window weather-strip. Problem with the top is when I drive 65mph, wind will whistle through the center of the top and if it leaks air then it will leak water.
C4 Targa Soft Top lightweight and falling
Just realized you have the top everyone says existed years ago. I could never find info on it. You mentioned that the header leaks at 65 mph. I knew that would be a possible problem, trying to keep the header profile thin between the two mounting points. I am now reinforcing that section ,Thanks
I have a ton of questions: Construction, Frame material, Type hinge , Header seal, Side window seal " you said OEM" ( I was trying to avoid that price ), Rear seal , Side tension cables , Top material "Haartz" ?, Side pads, Folded size, Weight , How did it store in the trunk , How much space was left , At 65 mph : Noise, Ballooning of fabric , Vibration, At higher speeds what would happen ? Finally : How did it look like GM made it ? Price? A lot of questions yes, you are my only connection to the past. My Proto type Specs : Frame: Aluminum 6061 flat bar stock Weight: Approx 10 to 12 lbs Folded size : 14" x 44" X4" high Top mat'l: Haartz Side pads Side tension cables Weatherstripping : Header, Rear and Sides Thanks in advance The Designer |
Sorry, cannot get more specific on how it was designed. Was not cheap, $475 from Corvette Central. After I found out it leaked air going down the Interstate I didn't use it much. Never seen rain. Another flaw is the front mounting positions. The main adjusting hardware for the 2 bolts (by the visors) is incased in a plastic frame and if the plastic breaks then new adjustment will be impossible. So right now I have no problems attaching the top to the windshield frame to my car. Will I use the top again, I doubt it but makes a great back-up top.
My C4 was a part time DD from 1995 to 2007 where I purchase a 2007 C6. Trade in on my 88 was so low I kept it. Now I am driving a 2015 C7 and my 35th C4 is slowly being restored (needs new paint) which I am in the process of doing all the prep work myself, this coming fall and winter. https://cimg5.ibsrv.net/gimg/www.cor...6ae1c0fb5c.jpg |
I'll take a few pics when I get back home on Sunday and post them for you.
There is also the fox rain coat soft top. I have one. I haven't installed it yet on my Vette because I need to repair it first (it was damaged in shipping from the guy I bought it from). But the same general principle.
https://www.ecklers.com/corvette/cor...-121896-1.html |
C4 Targa Soft Top
Thanks for getting back to me. Love your C4 absolutely beautiful, side pipes 👍🏻👍🏻👍🏻👍🏻👍🏻. I have a long way to go before mine looks like yours. I got sidetracked for a year with this Soft Targa Top build.
It would be great if you could send pictures of your top I need to know what it looked like My Soft Targa Top that I designed and built looks as if General Motors manufactured it as an option . That was the plan from the beginning because I couldn't find anything on the Internet . As we speak I am reinforcing the front header Per your suggestion about water leakage. Regarding the front mounting bolts my top has a floating attachment system that uses the C4 existing bolts . Right now my top fits '84, '85 and early '86 ( first mounting configuration ) and can be easily adaptable for the other two later configurations Looking forward to seeing the pictures . Also send pictures of the C7 All input is greatly appreciated The Designer |
C4 Targa Soft Top
Thanks for the info on the "Rain Coat "
Nice top . I wanted something that I could leave on and take off easily so I would never have to use the heavy targa top. This is the main reason why I decided to build this . Almost complete Thanks Again The Designer |
Here are the photos of the Vette Top
https://cimg7.ibsrv.net/gimg/www.cor...3cbfd3bf6e.jpg https://cimg0.ibsrv.net/gimg/www.cor...12fb667a0e.jpg https://cimg9.ibsrv.net/gimg/www.cor...ea1aa7b5ce.jpg https://cimg4.ibsrv.net/gimg/www.cor...913a2857b6.jpg OEM weatherstripping https://cimg3.ibsrv.net/gimg/www.cor...6cff6ce99e.jpg center hinge https://cimg7.ibsrv.net/gimg/www.cor...fc18ea0229.jpg |
C4 Targa Soft Top
HAD2HAV2
Thanks for the photos, exactly what I was looking for. I see the mounting points, in the Plastic Header, are deteriorated and further use , like you said , wouldn't be possible to install properly. Passenger side is really bad. Vibration will cause this type of damage. All and all it looks like a nice top, I can see why you purchased it. $475 wasn't bad back in 1998 for the design and construction of it. It's too bad that it didn't hold up. My design is different and soon as I can figure how to post pictures on CF I'll show you my top. Thanks again for your time and photos. The Designer |
If your design does not use Velcro that would be a huge plus. I'm interested to see what yuo come up with!
(Post 1594648392)
HAD2HAV2
Thanks for the photos, exactly what I was looking for. I see the mounting points, in the Plastic Header, are deteriorated and further use , like you said , wouldn't be possible to install properly. Passenger side is really bad. Vibration will cause this type of damage. All and all it looks like a nice top, I can see why you purchased it. $475 wasn't bad back in 1998 for the design and construction of it. It's too bad that it didn't hold up. My design is different and soon as I can figure how to post pictures on CF I'll show you my top. Thanks again for your time and photos. The Designer Interested on what you can come up with. |
C4 Targa Soft Top
Originally Posted by 85 Stalker
(Post 1594648774)
No Velcro was used in my Top. It looks, and folds back, just like a standard convertible top. Has Weatherstripping (not OEM) at the header, rear frame, side windows and all are adjustable. Thanks to HAD2HAV2 suggestions and photos . I am in the process of finalizing the prototype and soon will be posting photos. Thanks again THe Designer |
(Post 1594655892)
Thanks for the interest.
For c72016
Originally Posted by daverulz
(Post 1594627294)
Didn't realize they offered the fox raincoat to fit newer Vets interesting
As I said in my post earlier I wanted something that I could leave on and replace the heavy hardtop Soon will be posting photos of the top I designed |
C4 Targa Soft Top
C4 Targa Soft Top
https://cimg6.ibsrv.net/gimg/www.cor...d78b491e7e.jpg
To Remove Top:<br/>Disconnect (2) front mounting bolts and fold back.<br/>At the rear are (2) knobs, that replace the ratchet tool. Turn knobs CCW 6 to 8 turns and remove top. |
C4 Targa Soft Top
https://cimg8.ibsrv.net/gimg/www.cor...de269d8df6.jpg
Folded top stores neatly in back, utilizing existing brackets, secured with straps.<br/><br/><br/> |
