Brembo Brake Packages
CHEVROLET CORVETTE C6 Z06 | GRAND SPORT FRONT 6-PISTON MONOBLOCK | 350X34 MM (13.8") | 2-PIECE DISCS TYPE III SLOTTED ONLY
(F) 6-Piston Cast Monobloc Calipers | 350x34mm (13.8'') 2-Piece Discs | Complete Axle Set | Pre-Assembled | All Necessary Hardware Included Caliper Caliper Body: Cast Monobloc Radial Mount Caliper Piston Configuration: 6-Piston Caliper Piston Design And Insert Type: Inner Pressure Seal / OEM Approved Dust Boot Disc Disc Type: Type 3 Disc Material/Finish: Advanced High Carbon Alloy / Corrosion Resistant Plating Disc Diameter: 350mm Disc Width (Measurement): 34mm Disc Air Gap (Measurement): 17mm Disc Annulus (Measurement): 68mm Disc Construction: 2-Piece Disc Assembly Disc Vane Design (Measurement): Vented Curved 48 Vane Disc To Hat Mounting System: Floating D-Bobbin with Anti Rattle Spring Included Hardware Brake Lines: Proprietary Brembo Stainless Steel Braided Brake Lines by Goodridge Mounting Hardware: Brembo Engineered CNC Billet Caliper Adapters - All Necessary Hardware Included For Ease of Installation https://www.corvetteforum.com/forums...-3-red-med.jpg http://www.xplosiveperformance.com/C...ly_p_2987.html CHEVROLET CORVETTE C6- 6-PISTON MONOBLOCK | 350X34 MM (13.8") | 2-PIECE DISCS Product Description: (F) 6-Piston Cast Monobloc Calipers | 350x34mm (13.8'') 2-Piece Discs | Complete Axle Set | Pre-Assembled | All Necessary Hardware Included Front or Rear System Shown: Front Intended Use: StreetTrackRace Caliper Caliper Body: Cast Monobloc Radial Mount Caliper Piston Configuration: 6-Piston Caliper Piston Design And Insert Type: Inner Pressure Seal / OEM Approved Dust Boot Disc Disc Type: Type 3 Disc Material/Finish: Advanced High Carbon Alloy / Corrosion Resistant Plating Disc Diameter: 350mm Disc Width (Measurement): 34mm Disc Air Gap (Measurement): 17mm Disc Annulus (Measurement): 68mm Disc Construction: 2-Piece Disc Assembly Disc Vane Design (Measurement): Vented Curved 48 Vane Disc To Hat Mounting System: Floating D-Bobbin with Anti Rattle Spring Included Hardware Brake Lines: Proprietary Brembo Stainless Steel Braided Brake Lines by Goodridge Mounting Hardware: Brembo Engineered CNC Billet Caliper Adapters - All Necessary Hardware Included For Ease of Installation https://www.corvetteforum.com/forums...-thumbnail.jpg http://www.xplosiveperformance.com/C...cs_p_3351.html CHEVROLET CORVETTE C6 Z51 05-09 6-PISTON MONOBLOCK | 355X32 MM (14") | 2 PIECE DISCS FRONT Product Description: (F) 6-Piston Monobloc Calipers | 355x32mm (14') 2-Piece Discs | Complete Axle Set | Pre-Assembled | All Necessary Hardware Included Wheel Fitment: How to Measure Wheels for Required Clearance Brake Profile Cross Section Front or Rear System Shown: Front Intended Use: StreetTrackRace Caliper Caliper Body: Cast Monobloc Radial Mount Caliper Piston Configuration: 6-Piston Caliper Piston Design And Insert Type: Inner Pressure Seal / OEM Approved Dust Boot Disc Disc Type: Cross Drilled Slotted Type 3 Disc Material/Finish: Advanced High Carbon Alloy / Corrosion Resistant Plating Disc Diameter: 355mm Disc Width (Measurement): 32mm Disc Air Gap (Measurement): 16mm Disc Annulus (Measurement): 54mm Disc Construction: 2-Piece Disc Assembly Disc Vane Design (Measurement): Vented Curved 48 Vane Disc To Hat Mounting System: Floating D-Bobbin with Anti Rattle Spring Friction Material Pad Compound: Brembo High Performance FM1000 Pad Volume / Surface Area: 94.5 | 84 Included Hardware Brake Lines: Proprietary Brembo Stainless Steel Braided Brake Lines by Goodridge Mounting Hardware: Brembo Engineered CNC Billet Caliper Adapters - All Necessary Hardware Included For Ease of Installation https://www.corvetteforum.com/forums...umbnail-1-.jpg http://www.xplosiveperformance.com/C...t-_p_3359.html COMING THIRD QUARTER the NEW NEW GT-S caliper, NEW BM-4 caliper, NEW BM-6 The race inspired Brembo M6 and M4 calipers are perfect for the club racer or weekend track day enthusiast that wants to take that next step in braking. The M6 is a six-piston aluminum front caliper with performance properties gleaned from the company’s endurance caliper that helped the Ford GT win the 24 Hours of Le Mans. The pistons, with racing style radiators and no external dust seal, provide the best combination of performance and long-lasting track use. The calipers are hard anodized for longevity and resistance to corrosion at high temperatures. The Brembo logo is racing style, engraved in red, as seen on all of the company’s competition products.The new six-piston M6 calipers and four-piston M4 are derived from the current Brembo Gran Turismo (GT) performance caliper family. This makes the new components fully interchangeable with the GT kits, allowing them to fit under the same size wheels and accommodate the same size rotors while providing increased performance. In fact, the M6 and M4 calipers can be referenced through the same application list as the GT brake systems. The M6 is a front caliper designed for a disc that measures from 350 to 405mm, with a thickness of 32 to 34mm. The M4 is used for the rear axle as well as for some front applications and wraps around disc sizes from 328 to 380mm. The M6 and M4 share the same Brembo design characteristics that have been proven at the top rungs of motorsport for over 40 years. https://www.corvetteforum.com/forums...-brembo-m4.jpghttps://www.corvetteforum.com/forums...rembo-m6_1.jpghttps://www.corvetteforum.com/forums...ckages-gts.jpghttps://www.corvetteforum.com/forums...s-image003.png |
