Cleaning underside of car
I keep the outside and inside of my c6 spotless, however looking under the car its pretty dirty. How is the best way to clean the underside?
Drive rhrough a puddle of clean water. :lol:
Jack it up, put it on your jack stands, remove the tires and wheels and soap it up and hose it down.
Originally Posted by jrose7004
(Post 1594764072)
Originally Posted by dcarter0001
(Post 1594764311)
...I found out he hard way the pressure washer will tear up the window screens on a house.
(Post 1594763985)
Could always buy some jack stands, or a quick jack :hide:
NSF |
I've used a pressure washer under the car before. Just be careful as to what you spray. First thing though is that you need to go to the auto parts store and get you some jack stands. You shouldn't even be under one corner of your car without one.
Originally Posted by ruxvette
(Post 1594764336)
Not very handy, are ya Carter...:D
(Post 1594764400)
Just lazy, tried to clean the windows without removing the screens.
NSF |
(Post 1594764400)
Touchless car wash that has an undercarriage wash.
Buy jack stands and use them. I use 6 ton stands. Don't forget the pucks. Get under there and use some elbow grease and a good cleaner. I've been using wax and grease remover that body shops use. Makes the cast aluminum on the control arms look good too.
Originally Posted by jaredtxrx
(Post 1594765313)
Well, did the windows get cleaned?:crazy:
Originally Posted by LMB-Z
(Post 1594766588)
https://cimg5.ibsrv.net/gimg/www.cor...a62d6255f7.jpg
https://cimg0.ibsrv.net/gimg/www.cor...8194acbb54.jpg On a lift |
I don't go out in the rain, but have been caught in the rain while out a few times. Its an 06 Z06 with 58k miles on it. :thumbs:
My cousin has an undercarriage so clean that he lays under his car to comb his hair and brush his teeth.
(Post 1594764392)
http://i63.tinypic.com/ic2x4o.gif http://i1170.photobucket.com/albums/...r/579548ed.gif http://i1170.photobucket.com/albums/...r/579548ed.gif http://i1170.photobucket.com/albums/...r/579548ed.gif |
I use the Purple Power spray from Advance Auto Parts and then rinse with a hose.
https://shop.advanceautoparts.com/p/...m=purple+power |
