Johnny O'Connell Stage 1 Signature Series Suspension Kits - C7
https://cimg3.ibsrv.net/gimg/www.cor...85f7e609f5.gif https://cimg5.ibsrv.net/gimg/www.cor...6827ec63a5.png Johnny O'Connell Stage 1 Signature Series Suspension Kits https://cimg4.ibsrv.net/gimg/www.cor...c37c15986a.jpg Looking for the most bang for the buck in your Corvette Suspension Upgrade, then look no further than the the Johnny O'Connell Stage 1 Suspension Kit. This kit comes with everything you need to Upgrade your Corvettes Suspension to track level performance, while still keeping the drivablilty of a street car. Upgrading these components will give your Corvette a better balanced, better performing and more easily managed suspension on the street as well as the track. Each Kit Includes: - (4) Lowering Bolts - (F/R) Johnny O'Connell Sway Bars - Upgraded Sway Bar End Links - (4) Sway Bar Bushings Get your Stage 1 Package with https://cimg0.ibsrv.net/gimg/www.cor...d0216f204f.gif CCA Johnny O'Connell Stage 1 Corvette Suspension Package Regards Chip |
is this aimed more towards stingray and GS? this couldn't be better than a stock z06 suspension...?
Originally Posted by trevor90
(Post 1598768505)
This set up gives a better balance front to rear We do see Z06 owners swapping out for this suspension kit. It makes weight transitions more controllable and predictable The vast majority of sales are for non z51 cars - which is very notable difference Regards Chip |
https://cimg2.ibsrv.net/gimg/www.cor...8eea940099.png
All Current Orders are OTD :thumbs: Regards Chip |
What is the bar thickness vs a stock z06 ?
What's the bottom line on the coil overs?
I hear some systems ride horrible on the C7. Any input or related data and or articles would be appreciated. Thanks. |
Originally Posted by pavell
(Post 1603054105)
stock C7 Front (base model) - 26.2mm (hollow, 7.85 lbs) Front (all Z51) - 28mm (hollow, 7.95 lbs) Rear (base model) - N/A Rear (base Z51) - 26.5mm (hollow, 6.9 lbs) Rear (Z51 w/MRC) - 31mm (hollow, ? lbs) Rubber bushings (base model) Polyurethane bushings (all Z51) JOC Front 32mm - Rear 35mm Regards Chip |
All current orders are OTD :thumbs:
Regards Chip |
