Automatic Shift cable broke again
I have a 2003 50Th convertible with 33,000 miles. I like to shift the car manually from time to time. I have broke the cable a few years ago and it broke again Friday. Anyone have a solution to this problem? Car is stuck in first gear and need to take it in for repair. Is there an aftermarket solution?
Is it the cable or bushing? If it's the bushing, a new one can be snapped in to place.
Did it break in console or at transmission? I have a permanent solution at transmission. Remove the shift lever from transmission. Grind the back off the stud that connects to shift cable. Punch the stud out of lever. Tap the hole and put in a bolt. Put washers inboard and outboard on shift cable connector in place of the nylon ring thing. secure the cable connector to bolt on shift lever with a Nyalocck nut. Get the nut a little snug but not tight. Wish I had pictures. Hope that made sense. If mine ever breaks in console I will probable devise a similar solution there. Good luck! :cheers:
Seems very unusual to have the same problem twice in just 33K miles.
(Post 1594839951)
Every time I see a thread like this it worries me.
Does it make sense to replace this cable preventatively? Seeing one break so quickly worries me even more. |
Originally Posted by 91LSMAN
(Post 1594840281)
(Post 1594840281)
Does it make sense to replace this cable preventatively? Seeing one break so quickly worries me even more. All right I'm with 91LSMAN in that I have a 2002 auto and all this talk about the cable pieces braking just makes me wonder just how BIG of a problem this is in the whole picture. I know that all you hear about are the problems, not the times that the cable lasts for thousands and thousands of miles and shifts. Curious minds want to know. Thanks!! |
Originally Posted by C52002Vert
(Post 1594841510)
:iagree:
Where and When
Two key points of failure (the "where") at the shifter and transmission connector. I had the trans end fail about 12 years ago and fixed that by reattaching the connector and holding the snap clip in place with two tie-wraps that held for years. I bought another shift cable about 2 years ago. Knowing full well at some point in time that the cable would fail at either the shifter or trans connector again (the "when"), I recently had the new cable installed. And the cycle starts all over again.:cheers:
Geez...how often does this happen generally with an auto C5? I've never heard of a shift cable breaking in any auto car...ever. :confused2:
Originally Posted by Slo Yelo C5
(Post 1594841689)
Replaced the nylon at the console end on a friend's 2002 a few months ago. I think he has about 110k miles. |
Originally Posted by MAC5
(Post 1594841636)
I think we are seeing more posts like this because of the age of the cars. I just bought a new cable online last night. I'll probably have it replaced preventatively during one of my next oil changes. :thumbs:
Originally Posted by UM Rebel
(Post 1594841929)
My guess is that they will all eventually fail. More a matter of time than miles. Those nylon gromets (or whatever they are called) will deteriorate and the connector at one end or the other will fall off the stud. I had to replace the cable in my 2004 last year at about 90k miles. Would have only had to replace nylon thing except I broke the cable trying to reattach to the shifter.
Replaced the nylon at the console end on a friend's 2002 a few months ago. I think he has about 110k miles. How much (just an estimate) are parts for this job? How much do you think labor hours at a shop would be? |
(Post 1594842269)
Interesting information. Thanks!
How much (just an estimate) are parts for this job? How much do you think labor hours at a shop would be? http://www.dormanproducts.com/itemde...9&SEName=14055 A complete new cable is about $60 dollars and it took me 3 days and language you wouldn't want the children to hear to replace that. Again a shop should do it much quicker. There is rarely a reason to replace the entire cable.:cheers: |
Is there a site or number that works?
This says its not for a c5 https://cimg6.ibsrv.net/gimg/www.cor...634465a55c.jpg |
Originally Posted by sloopdawg
(Post 1594842674)
This says its not for a c5 https://cimg6.ibsrv.net/gimg/www.cor...634465a55c.jpg 97-03 C5 Genuine GM Corvette Shift Selector Cable Shifter GM Shifter 12561688 for additional info. |
Wondering how many removed the torque tube, to install the cable? I used a sneaker lace and fed thru the top. I found this info on Internet or perhaps here. I had no idea the nylon bushings were available. Gonna purchase those bushings, have them on hand, either for myself or a Vette brother.
Found and Ordered Here
