Electrical problem with led bulbs in dash.
I switched over to led lights in the dash and center gauge with both led bulbs as well as rgb led strips. The led bulbs are turned on via the headlight switch and the rgb led strips are powered on when you turn the key to on.
Problem: With the ignition key off/on and seat belts unbuckled/buckled seats occupied/unoccupied the seat belt light is always dim and won't turn off. In other words, my problem is the seat belt light will only turn off if I disconnect the battery and it's always dim, not bright. I'm not sure if it's related to the led bulb conversion or it's a seat belt electrical issue, therefore I'm not sure if I need to remove the center gauge area and check the wiring or remove the seat and check the harness underneath the seat. If memory serves me right the seat belt light should only turn on with the ignition in the on position, seatbelt unbuckled and someone sitting in either the drivers or passenger seat? Any suggestions before I remove the dash to investigate? |
my best guess the problem is the seat belt switch,
the wire might be pinched creating a short, or it has some minor corrosion within the switch assemble, and is slightly conducting all the time. fix the switch first. then determine where power feed comes from 12v with switch on, or always 12volts. also make sure the console bezel is grounded properly. if you do not have proper ground, it can back feed thru leds seeking ground. creating a dimly lit led. |
Without knowing exactly where you connected and are drawing power to make the LED strips work..it is hard to guess.
I would back track and disconnect the LED strips and see if that corrects one problem and then find another wire to make the LED strips work. Knowing your year model is always helpful due to wiring changes. DUB |
Thanks for the replies
69Vett I believe the switch is located in the seat belt buckle? Does the seat belt light activate on both the drivers and passenger side on the 1975? It's odd that this problem would occur at the same time I'm doing the led bulb mod which is why I wonder if it's the switch but then anything's possible. I checked and the console is grounded as I needed to ensure in order to get the lights to work. DUB The led bulbs are wired into the headlight switch and the rgb led strips are wired into the radio power. I know it's not the strips as the strips are distributed throughout the center bezel and not in the 'seat belt light" area. Below is a bench test of the rgb led strips in red (cell phone pic) https://cimg1.ibsrv.net/gimg/www.cor...622c2ca4b3.png It's a 75 coupe. |
Update;
I've found that with the ignition off, there is low voltage (unable to determine how much as I didn't have a multi meter) enough to light up the led, but not the stock incandescent bulb. When I connect the seat belts with ignition off, no one sitting in the seats, there is even less voltage (noted by the led dimming more). It seems that the bulb socket works on ground? I unplugged the seat belt buckle located in the center console (where the e-brake is located) and there was no change. I placed another ground to the center gauge bezel and it made no difference. I'm unable to turn the seat belt led bulb off (dim at all times). |
OK...I will look tomorrow at work and see what I can find in the wiring diagram. I do not have one here at home.
What wire are your LEDs wired into at headlight switch??? When you say 'radio power' I am assuming the yellow wire that would power your stereo. AND are you ONLY using that yellow wire that is your radio wire power for the LEDs????...or are you ALSO using it for the radio?????....AND...is your stereo factory or aftermarket????? DUB |
Originally Posted by DUB
(Post 1594892636)
DUB
(Post 1594892636)
DUB For sake of trouble shooting I should have not even mention the led rgb led strips as they're turned off and are not part of the problem. When changing over to the led's I installed two led set ups, the led bulbs would be used 90% of the time and the led rgb strips would be used only for effect and were on a separate circuit. |
Originally Posted by Maymyvetteliveforevr
(Post 1594892440)
Update;
I've found that with the ignition off, there is low voltage (unable to determine how much as I didn't have a multi meter) enough to light up the led, but not the stock incandescent bulb. When I connect the seat belts with ignition off, no one sitting in the seats, there is even less voltage (noted by the led dimming more). It seems that the bulb socket works on ground? I unplugged the seat belt buckle located in the center console (where the e-brake is located) and there was no change. I placed another ground to the center gauge bezel and it made no difference. I'm unable to turn the seat belt led bulb off (dim at all times). Does it light up properly when it should? Do you know what colours are used for this lamp? 1975 had two different systems for this. Earlier models had an interlock system (which was mostly bypassed due to problems with it) while later models had a more simple warning system. Knowing which yours is would make it easier. |
Originally Posted by Antz81
(Post 1594894535)
(Post 1594894535)
(Post 1594894852)
No, with the led light installed it stays dim all the time even with the ignition off. I installed a red led bulb and I took possession of the car on Jan 3rd 1975 so it was an early model.
If it was an early model that would mean when you got it then you would have had to have your seatbelt buckled up to start the car. (Unless the interlock system was bypassed before you took possession). With the interlocked system the seatbelt warning light is switched by a control unit. I suspect (I've never seen the inside of one) that it is a transistor switch for this. If that is true then to get your light to turn off fully then you'll need to install a relay, or swap back to a normal bulb. That's one of the flaws with solid state switching, they still allow a small current to flow, just enough that LEDs just start to light up. |
you do know some Leds can be installed backwards right ?
flip the LED if it is a bayonet type socket. |
Thanks for the replies people.
(Post 1594894881)
I was meaning when the lamp should be on does it light up properly?
(Post 1594894881)
Originally Posted by 69Vett
(Post 1594896410)
flip the LED if it is a bayonet type socket. With the normal bulb it won't turn on at all. |
(Post 1594894852)
This type of response is what confuses me due to when dealing with a problem...being extremely clear in what you are communicating... takes any doubt of what you are writing...which helps. SO if the red led light is NOT installed..does the light stop being dim...which I am assuming is the seat belt light??? DUb |
(Post 1594893090)
The led bulbs are wired into the light switch and I thought there was only one power wire, either way, the rest of the led bulbs work fine except for the seat belt light.
Still.... It would be nice to know what color wire you attached your LED's to???? I used the radio wire for the led strips, my problem is with the led bulbs, not the strips. in other words, the led bulbs are wired into the headlight switch and can be dimmed. The led rgb stips are wired into the radio power and are turned off via a remote. So the LED strips are wired to an outgoing wire from the radio???? Or did you wire them in withe incoming power..and which color wire did you attach these LED strips to??? For sake of trouble shooting I should have not even mention the led rgb led strips as they're turned off and are not part of the problem. When changing over to the led's I installed two led set ups, the led bulbs would be used 90% of the time and the led rgb strips would be used only for effect and were on a separate circuit. DUB |
(Post 1594899628)
I am assuming that "IT" is the seat belt light??????...or is it that the LED's are staying lit????
This type of response is what confuses me due to when dealing with a problem...being extremely clear in what you are communicating... takes any doubt of what you are writing...which helps. SO if the red led light is NOT installed..does the light stop being dim...which I am assuming is the seat belt light??? DUb When I remove the led seat belt bulb, there is no bulb therefore it can't be dim. When I reinstall the original bulb it never lights up regardless of whether the seat belt is buckled, the ignition is on/off, or any other option.
(Post 1594899669)
BUT if this seat belt light was not burning dim BEFORE you did this...knowing exactly what you did and where you connected the wires to and to what color wires can make a difference.
DUB Ok, I remember now, I never changed any wiring when I installed the led bulbs as I only removed the oem bulbs and installed the led bulbs so it still operates off of the oem headlight switch as I'm using the oem wiring/sockets. Yes, the led strips are wired to the radio power wire, but for the purpose of this diagnostics, I've turned the led rgb strips off and they don't connect to the seat belt light, the only light up the gauges therefore it's a totally different circuit which is not in use at the moment. I don't see how the led rgb strips are related to the led bulbs as they're on a totally different circuit and I'm not having problems with them as the don't interfere with the seat belt light at all. |
(Post 1594900131)
Yes, "it" is referring to the seat belt light only, not all the led lights.
BUT..for whatever it is worth...It is really critical that when you do any conversions or electrical 'what ever's' and have a problem..a very detailed description is required. In your initial post it kinda reads that you did all the bulbs in LED's if a person wanted to read it that way...or it could read that all you did was the lights for your gauges in red LEd's....becasue it was not clearly written that way with no confusion. And now you stated that not all re LED's...which does make a difference.
(Post 1594900131)
IF the factory bulb is NOT dim or even working...BUT the LED bulb is dim...then you can have a scenario like was mentioned in one of the past posts that the LED is dim because it takes so little current work...it is dim...but not enough current to make the incandescent bulb shine.
(Post 1594900131)
I recently did a body off restoration as the car sat for 26 years. I don't remember if I had an issue with the seat belt light once the car was complete as I had many other issues to deal with. In other words, I never noticed. I'm going to assume I had this issue before I did the led conversion as the oem bulb would have been installed and it never would have turned on.
(Post 1594900131)
AS I wrote above....I will look at my diagram and see what is going on.....that is IF you want the seat belt circuit working or not??? DUB |
DUB
First off, thanks for sticking with me on this electrical issue as I know electrical gemlins can be a major pain in the arse which most people don't want to attempt to help out with. Secondly I apologize for the confusion. Thirdly, I shouldn't have mentioned the led rgb strips in my initial post as it's totally unrelated to my problem. This is the statement that describes my problem and thanks for putting in your own words. I don't believe it will make a difference but in doing the dash and center gauge, I used 4 different led color bulbs, white, blue, green and red. The red is what I used for the "seat belt warning".
(Post 1594906289)
DUB |
(Post 1594908867)
DUB
First off, thanks for sticking with me on this electrical issue as I know electrical gemlins can be a major pain in the arse which most people don't want to attempt to help out with. Secondly I apologize for the confusion. Thirdly, I shouldn't have mentioned the led rgb strips in my initial post as it's totally unrelated to my problem. This is the statement that describes my problem and thanks for putting in your own words. I don't believe it will make a difference but in doing the dash and center gauge, I used 4 different led color bulbs, white, blue, green and red. The red is what I used for the "seat belt warning". Kinda surprised this hasn't been added to the mix. Those mini leds offer nearly zero resistance, and require so little voltage to light up, a little feedback is all that is required to kick them into gear. Load the circuit in question then chime in with your thoughts. |
At this point, I would get the seat belt warning circuit working with the stock bulb first (do make sure it's good). Then worry about converting it to LED and address any new issues that arise.
Originally Posted by lionelhutz
(Post 1594910034)
