Cup washers fell out of diff?
1 Attachment(s)
Thanks in advance. I am working on prepping my new diff for installation in my 1975 and got the mating surfaces on both halves cleaned up and was cleaning the bolts and washers and decided I would remove the stub axles to replaces the seals and inspect the axle ends and install new c clips. I got the small keeper bolt out, the center pin fell out easily, but then two "cup" washers also came out. They look like they may fit under the smaller toothed gears that the center pin slides into as the inside diameter is the same as the pin. My problem is that they came out very easily with just gravity when I turned the assembly, but I didn't see from where and I can't seem to figure out how to get them back in? I don't want to reassemble everything else until I know they are where they are supposed to be.
they are behind the smaller gears as you mention or spider gears.
Originally Posted by stingraymax
(Post 1594884238)
Yes those cup washer go between the spider gears and the posi case and will fall out when you least need them to....get the case in a position where you can get a washer in...align the spider gear with the cross shaft hole....jamb it in and install the shaft.....rotate posi housing to allow washer access for other gear...push cross shaft out....jamb the final washer in and check cross shaft position making sure you have hole for retainer bolt correctly oriented and get shaft into case....install reatainer bolt with red locktite....your done! You might have to use an aluminum or brass punch to get final washer fully placed behind the gear.
Originally Posted by Solid LT1
(Post 1594884301)
Originally Posted by Highlander1732
(Post 1594884198)
