Flywheel bolts part number
I need some flywheel bolts. My rear main went out and I read not to reuse fly wheel bolts. That being said what is the part number. I'm using a mantic twin disk clutch.
Correct about not reusing them being recommended procedure.....
GM part number is: 11569956 for the flywheel bolts and 12561465 for the pressure plate retaining bolts these are available from online vendors, including the big auction site if your local dealer isn't able to assist............. :yesnod: |
Originally Posted by rkj427
(Post 1594924898)
Originally Posted by bdickey058
(Post 1594924231)
My rear cover is leaking again. It was leaking at the top, not around the rear main. I may have to get a new cover as the cover may be the issue. Just an FYI.. I'm looking to replace my exhaust manifold bolts with OEM ones. Any one have the GM part number for those as well. |
GM's are plenty strong. Flywheel bolts, that is.
(Post 1594925021)
does arp make the bolts or will GM's be plenty strong?
Originally Posted by schpenxel
(Post 1594925410)
