Cross fire to carb
i recently got rid of my crossfire injection put a edelbrock torker 2 intake with a 650 cfm holley double pumper. Got a vacuum advance dizzy. All I need now is a fuel regulator
Cool. Should make about the same power as if you had ported the stock intake. :thumbs:
Fuel injectors both clogged was not worth replacing both at 110 each.
Originally Posted by Jdog91
(Post 1594945244)
:cool: |
Let me hear it I want as much horsepower as possible
(Post 1594945244)
(Post 1594945244)
110 each for TBI injectors is too much. REMAN TBI IJNECTOR: $30 BUX
(Post 1594945244)
Definitely plan on going to track got the whole new setupfor 70 bucks from The app OfferUp. https://cimg6.ibsrv.net/gimg/www.cor...16750569a3.jpg
If anybody wants crosssfire parts I will sell them cheap I am in central New Jersey
(Post 1594947626)
That carb isn't a "double pumper", BTW. :thumbs: . |
https://cimg1.ibsrv.net/gimg/www.cor...5c1fe70fb3.pngNext mod will be the supercharger and hood cowl
(Post 1594948532)
Carb looks a little tired. I would rebuild it before I relied on it.
What can use to make the carb shine again.
Originally Posted by Taylor Allen
(Post 1594948633)
couldnt have possibly picked a worse air filter
Jdog, please dont use that "filter" as is; you have zero filtering properties. |
(Post 1594950050)
I'll see how it runs without the rebuild. But plan on rebuilding carb anyways. As for the air filter what do you suggest in terms of a better one seems I will have to cut a hole in the hood either way
(Post 1594950498)
http://www.jegs.com/p/JEGS-Performan...51908/10002/-1 https://cimg4.ibsrv.net/gimg/www.cor...d03ae3f805.jpg |
(Post 1594950498)
Unless your goal is to modify the hood, there is no reason to cut a hole in the hood. The 80 and 81s used a carb set up as you have, so the clearance is allready accounted for. The air cleaner in your photo is not (not) even remotely compatible. Get something like Taylor suggests and put the Saws-all back in the box. |
1 Attachment(s)
If you want to keep it EFI, you could do this. Your stock wiring & ecm will hook up & run it. The junkyards are full of tbi units, crossfire is basically the thing as a 2 barrel tbi.
