My floorjack failed and I was going to toss it....
...and then I found this cool website about how they're built, and how to repair. Hopefully useful to someone:
http://www.garagejournal.com/forum/s...ad.php?t=51105 |
my problem is the kits are 45$ and the new 3 ton jack at harbor freight is 67$ on sale. Ain't worth the 2 hours of time and dirty hands.. just go out and buy a new one.
but still, thanks for the post, nice to have a tutorial. |
good point...
If mine isn't an easy fix and/or adjustment, then I'll check out harbor freight for that price.
Originally Posted by joewill
(Post 1594951224)
I have (2) of the 3 ton low profile HF floor jacks....Good quality for the price.
Brian |
https://cimg6.ibsrv.net/gimg/www.cor...1d5a307527.jpg
Originally Posted by carriljc
(Post 1594951112)
http://www.garagejournal.com/forum/s...ad.php?t=51105 The Daytona jack is excellent. :flag: |
(Post 1594951224)
but still, thanks for the post, nice to have a tutorial. This is still a hard fact to swallow. Several articles I read years ago stated the older jacks were much better quality steel and it was often better to rebuild than to buy new. But now, the cost doesn't make sense. Spend as much or more rebuilding, or buy new with a warranty. No wonder our landfills are growing so fast. |
Originally Posted by Mark_Milner
(Post 1594953937)
But now, the cost doesn't make sense. Spend as much or more rebuilding, or buy new with a warranty. No wonder our landfills are growing so fast. Good point! |
Originally Posted by caskiguy
(Post 1594951938)
Originally Posted by BKbroiler
(Post 1594955469)
Caskiguy - That jack lifts that car high enough to get those stands under the wheels while they are hanging on the suspension? That's got to be 30 inches.
The stands allow for full movement, very stable, car has now been on them for 8 months. If interested check out--- Myliftstand.com :flag: |
Looks like mine is more than a simple adjustment. Guess I'll just go to harbor freight and see what's on sale.
I was going to toss the old one, but I'm thinking I'll "repurpose" those heavy duty wheels and adapt them to roll around my wooden engine stand..... and that long jack handle looks like a good "persuador" to keep. |
(Post 1594958048)
(Post 1594958065)
Go to their website and download a 20% discount coupon.:flag:
(Post 1594955947)
Actually the stands compress(spring loaded with locking pins). One places the jack inside the stand and lifts the car, pins lock in place on the stand. Move to the next wheel and so forth. Or just use two stands. The Daytona jack will extend 23 1/8" perfect for what I needed.
(Post 1594955947)
The stands allow for full movement, very stable, car has now been on them for 8 months. If interested check out--- Myliftstand.com :flag: DT |
$550 a set of 4, plus shipping, probably 650 for the set delivered.
My old Sears floor jack bit the dust after some decades of use, and it did not fit under the Miata my wife had.....so yes HF and the orange lo profile jack and I put a larger piece of doubled up 3/4 ply on the cup and even stack a 4x4 on top sometimes, and a 2x4 on edge for lifting the rear of my '72, fits between the exhaust pipes just fine......
:smash::rock: |
Originally Posted by mrvette
(Post 1594964030)
:smash::rock: |
I have an old long frame hydraulic jack that I bought from Harbor Freight decades ago. I really like it because it can lift a car about 3 feet off the ground. Anyway, the main piston seal disintegrated, hard plastic type, and of course HF no longer carried repair parts. Mcmaster Carr sells hydraulic seals and I found one in the right OD but a bit small on the ID, machined the piston to fit which was really easy, cheap if you had to get it done and wallah, $7 dollars fixed. The other seals were basic O rings but I didn't bother replacing them. 5 years ago and still going strong. You know they suggest you do oil changes on hydraulic jacks! does anyone really do that? I don't.
I'm going to head to Harbor Freight and see what's available. Looks like they have an aluminum floor jack on sale for cheap...... can't tell what it's like from the ad though.
(Post 1594951112)
