A/C Not Blowing Cold Air
I am hoping someone can help me. Have an 08 and with a/c on it blows way cooler on the pass side compared to driver side. I am sure it does need charging. Both are set on 60 degrees. Any idea what the problem is?? Thank you!!
Originally Posted by matmanls308
(Post 1595020709)
Tried the controller (expensive rebuilt) and it worked for awhile but the auto function for the fan didn't seem to work right. Replaced control head again and still had issues so tore into the system to check for a bad valve. It turns out there are not individual valves but a ridiculous box with plastic sheeting rolled up on rollers to control distribution of cooled/heated air to the sides and that box is another very expensive item. My work was done by a local mechanic I no longer use so maybe your experience will be better than mine. Best of luck. John |
(Post 1595020709)
I just looked at gmpartsdirect.com and it appears to me the "box" he replaced could maybe have been rebuilt with individual components rather than replacing it in it's entirety. Would have been much cheaper if that is possible. He also charged a lot of labor based on the stated difficulty of getting to the box, maybe or maybe not. John |
(Post 1595020709)
Originally Posted by PCMusicGuy
(Post 1595022822)
Do you by any chance have HUD that was installed separately?
Originally Posted by jwswanson
(Post 1595020973)
I should add that I stopped using the mechanic because I felt like he was overcharging me despite having used his shop for many years and many cars.
Not sure if the C6 is the same way but a big reason in the Cadillac Deville of the early 2000's is a slightly low refrigerant charge. The passenger side gets the "cooler" end of the evaporator airflow first, so the driver's side is then starved for cool air - sort of like the hot and cool ends of a radiator. Try this first.
Originally Posted by Sky High
(Post 1595024416)
(Post 1595023009)
Thank you for that info. So this would not be an diy project? Sorry I haven't even look at a breakdown or anything.
If you can talk to a good C6 corvette mechanic he may be able to help decide what the actual problem is. Mine was not just slightly warmer air but rather hot air on the passenger side and cold on the driver side so that sounds a bit different than your description. John |
First check that the clutch is engaging. Since you have some air aligns like it is.
second take a low pressure side reading wit the car running and A/C on coolest setting. Sounds like you are sitting likely around 20 psI if it's a case of low coolant. If that's the case fill to proper levels. I suggest using the coolant with sealant and oil already included. if that all doesn't fix your problem use a manifold gauge set to take a high and low pressure reading to see if there is any sort of blockage or other issues and then work from there. no need to dump money paying someone yet until you eliminate the easy stuff. I had an issue like this on another car where half the car blew hot the other slightly cooled. Paid to recharge it several times. Had a leak on the low pressure side gasket that the stop leak stuff fixed. Wish I had tried that first before paying to have it recharged. |
Originally Posted by flyingbunnys
(Post 1595026850)
DO NOT use stop leak...... I worked in refrigeration for almost a decade. In most cases it just makes things worse and leaves you with blockages and needing to replace a lot more than the leaky component.
(Post 1595020709)
I had the same situation on my 2012GS. Took the car to Kerbeck. They tested the system for leaks and found none. The only issue found was low on refrigerant. Charged the system and its been fine ever since. This was April of 2016. Maybe you'll get lucky. :thumbs: I forgot to add, my air re-circulation button was not turning off. The little light was always on and forcing more air (warm) out. That was also resolved with the charge. |
