Corvette Camaro Tuner in Tampa
Check out my website -->> www.TampaTuning.com
Tampa Tuning is the home for street performance tuning for $325 on Corvettes and Camaros at the stock to bolt ons level. My street tuning process takes several hours to complete. It the best way to collect scanner data for low end drivability and WOT under actual load and airflow of the vehicle. My HP Tuners interface has unlimited credits for LS1, LS2, LS3, LS6, LS7, LSA, LS9, L99 engines :thumbs: C7, Gen6 Camaros, and trucks are $100 more. Great modification for the buck! Corvette Camaro Tuner in Tampa Instagram : TampaTuning OUR TOTAL STREET PERFORMANCE TUNING PACKAGE FOR GM LS1-7 VEHICLES IS $325.00 WITH TRANSMISSION PACKAGE INCLUDES: Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results Increase power enrichment rate mode Examine and change timing tables for additional horsepower & torque gain Optimize your vehicles Air and Fuel Ratio monitored by the NGK/ AFX wideband unit Reduction of intake air temperature table (heat soak) Desired rev limiter adjustments Park, neutral, and in- gear idle adjustments with and without A/C active Adjust power enrichment delay to immediate Engine torque management system reduced Transmission torque management system reduced Transmission shift points enhanced Transmission shift times reduced Transmission shift pressure firmness enhanced if needed Skip shift deleted (CAGs 1st to 4th ) Fuel injector rescaling for aftermarket injectors if needed Cooling fan activation temperature and percentage of cooling recalculated Perform speedometer recalibration for rear gear ratio and tire size change Turn off check engine light and remove trouble codes Tuning@TampaTuning.com Phil |
Thank you service men and women for giving us the opportunity to be able to barbecue and live freely today. Happy 4th of July and be safe!
Corvette Camaro Tuner in Tampa www.TampaTuning.com Phil |
Beautiful weekend to make your car faster :thumbs:
Originally Posted by Tampa Tuning
(Post 1595047859)
Tampa Tuning is the home for street performance tuning for $325 on Corvettes and Camaros at the stock to bolt ons level. My street tuning process takes several hours to complete. It the best way to collect scanner data for low end drivability and WOT under actual load and airflow of the vehicle. My HP Tuners interface has unlimited credits for LS1, LS2, LS3, LS6, LS7, LSA, LS9, L99 engines :thumbs: C7, Gen6 Camaros, and trucks are $100 more. Great modification for the buck! Corvette Camaro Tuner in Tampa Instagram : TampaTuning OUR TOTAL STREET PERFORMANCE TUNING PACKAGE FOR GM LS1-7 VEHICLES IS $325.00 WITH TRANSMISSION PACKAGE INCLUDES: Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results Increase power enrichment rate mode Examine and change timing tables for additional horsepower & torque gain Optimize your vehicles Air and Fuel Ratio monitored by the NGK/ AFX wideband unit Reduction of intake air temperature table (heat soak) Desired rev limiter adjustments Park, neutral, and in- gear idle adjustments with and without A/C active Adjust power enrichment delay to immediate Engine torque management system reduced Transmission torque management system reduced Transmission shift points enhanced Transmission shift times reduced Transmission shift pressure firmness enhanced if needed Skip shift deleted (CAGs 1st to 4th ) Fuel injector rescaling for aftermarket injectors if needed Cooling fan activation temperature and percentage of cooling recalculated Perform speedometer recalibration for rear gear ratio and tire size change Turn off check engine light and remove trouble codes Phil |
Tuner in Tampa Orlando
Saturday morning bump. Tuner in Tampa Orlando area
Follow me on instagram: TampaTuning |
Corvette Camaro Challenger Charger Truck Tuner in Tampa
Friday morning bump for the weekend as I take my kids back to University of Central Florida in Orlando and the other to University of North Florida in Jacksonville. Click on our website-> www.TampaTuning.com Thanks Phil |
Corvette Camaro Truck Tuner in Tampa
Thank you for allowing me to calibrate your Corvette. I hope each of you enjoy the three day weekend.
Thanks Phil Tuning@TampaTuning.com Corvette Camaro Truck Tuner in Tampa www.TampaTuning.com |
Good luck Florida friends with Irma.
Reach us at : Tuning@TampaTuning.com Check out our Website: www.TampaTuning.com Phil- Owner of Tampa Tuning. Corvette Camaro Truck Tuner in Tampa |
Bolt on throttle response and horsepower for $150 Bucks!
These CNC throttle bodies complement your Air intake system. Follow me on Instagram: tampatuning Corvette Camaro Truck Tuner in Tampa Home of the Street Performance Tune starting from $325 Check out our Website>> www.TampaTuning.com Phil https://cimg4.ibsrv.net/gimg/www.cor...151ebf5c18.jpg |
Corvette Camaro Truck Tuner in Tampa Orlando
Cool weather equals a quicker car. Lets throw some bolt ons on it and a tune, and make the car more fun
Reach us at : Tuning@TampaTuning.com Check out our Website: www.TampaTuning.com 813-727-8720 Phil- Owner of Tampa Tuning. Corvette Camaro Truck Tuner in Tampa Orlando |
Home of the $325 Calibration with HP Tuners and wideband for stock to bolt ons Corvettes and Camaros to be street race tuned.
The process takes about three hours. I fix a lot of local work because they do 3 pulls on the dyno and your done. That's not how you calibrate a Corvette. Tampa Tuning's in-depth computer process includes low end parking lot driving, cruising spirited driving and WOT. Tampa Tuning wants to make sure we cover ALL the ranges your car performs in. Price is $325 for 1997 to 2013 Corvettes. Price is $395 for 2014 to 2016. Cam'd and Supercharged Corvettes, Email me with build for pricing. <<<<<<>>>>>> Check out our Website: www.TampaTuning.com Reach us at : Tuning@TampaTuning.com 813-727-8720 Phil- Owner of Tampa Tuning. Corvette Camaro Truck Tuner in Tampa Orlando
(Post 1595898651)
Corvette Tuner in Tampa
(Post 1595999931)
The process takes about three hours. I fix a lot of local work because they do 3 pulls on the dyno and your done. That's not how you calibrate a Corvette. Tampa Tuning's in-depth computer process includes low end parking lot driving, cruising spirited driving and WOT. Tampa Tuning wants to make sure we cover ALL the ranges your car performs in. Price is $325 for 1997 to 2013 Corvettes. Price is $395 for 2014 to 2016. Cam'd and Supercharged Corvettes, Email me with build for pricing. <<<<<<>>>>>> Check out our Website: www.TampaTuning.com Reach us at : Tuning@TampaTuning.com 813-727-8720 Phil- Owner of Tampa Tuning. Corvette Camaro Truck Tuner in Tampa Orlando The process takes about three hours. I fix a lot of local work because they do 3 pulls on the dyno and your done. That's not how you calibrate a Corvette. Tampa Tuning's in-depth computer process includes low end parking lot driving, cruising spirited driving and WOT. Tampa Tuning wants to make sure we cover ALL the ranges your car performs in. Price is $325 for 1997 to 2013 Corvettes. Price is $395 for 2014 to 2016. 2017 and newer with Automatic transmission contact me for prices. Cam'd and Supercharged Corvettes, Email me with build for pricing. > Check out our Website for details: www.TampaTuning.com Reach us at : Tuning@TampaTuning.com 813-727-8720 Phil- Owner of Tampa Tuning. Corvette Camaro Truck Tuner in Tampa Orlando |
The process takes about three hours. I fix a lot of local work because they do 3 pulls on the dyno and your done. That's not how you calibrate a Corvette. Tampa Tuning's in-depth computer process includes low end parking lot driving, cruising spirited driving and WOT. Tampa Tuning wants to make sure we cover ALL the ranges your car performs in. Price is $325 for 1997 to 2013 Corvettes. Price is $395 for 2014 to 2016. Cam'd and Supercharged Corvettes, Email me with build for pricing. > Check out our Website for details: www.TampaTuning.com Reach us at : Tuning@TampaTuning.com 813-727-8720 Phil- Owner of Tampa Tuning. Corvette Camaro Truck Tuner in Tampa Orlando |
Corvette Camaro tuner in Tampa
A very Happy Thanksgiving to all our friends and those of you protecting us missing out on a family dinner.
www.TampaTuning.com Corvette Camaro tuner in Tampa Phil
(Post 1595047859)
Camaro Corvette Truck Tuner in Tampa
(Post 1595999931)
The process takes about three hours. I fix a lot of local work because they do 3 pulls on the dyno and your done. That's not how you calibrate a Corvette. Tampa Tuning's in-depth computer process includes low end parking lot driving, cruising spirited driving and WOT. Tampa Tuning wants to make sure we cover ALL the ranges your car performs in. Price is $325 for 1997 to 2013 Corvettes. Price is $395 for 2014 to 2016. Cam'd and Supercharged Corvettes, Email me with build for pricing. <<<<<<>>>>>> Check out our Website: www.TampaTuning.com Reach us at : Tuning@TampaTuning.com 813-727-8720 Phil- Owner of Tampa Tuning. Corvette Camaro Truck Tuner in Tampa Orlando |
