RPM holding up
Hello all I'm looking for some assistance.
I have a 2006 z06 . Car works perfectly when cold after it warms up, the engine rpm will be slow returning to ideal rpm between gear changes . Engine slows To around 3000 rpm normally when slow to approximately 2000 then slow as, from there down . Has any one had the problem . I changed the battery and checked for any code with a generic reader and nothing showing . I have just received a tech 2 and now need to work out how to read code with the new tool Bob |
Unless you shift very very slowly, the rpm should not come down to idle, if that's what you are expecting.:thumbs:
Originally Posted by cclive
(Post 1595111765)
I`ll put it this way when you shift out of third at 3000RPM and pull forth, the engine is at 3k as the clutch engines and that pulls the engine down . now if I am going a little harder and I shift up at 5500 out of first to second (with my foot off the pedal ). it hang on and all hell breaks loose , not what you want when your pulling out into traffic So I find my self selection neutral between gear and waiting for the RPM to drop to the appropriate revs. ( in traffic. ) Bob |
I am not understanding this thread ??? I will read back later....
I'm starting to think . I have a problem that is not a common one.
I ordered a new pedal sensor assembly today. |
Originally Posted by bfit
(Post 1595120839)
Originally Posted by Corvette_Ed
(Post 1595120888)
Did you check for any codes first? Just throwing parts at the problem isn't the best way to solve it.
Sounds like the TB is sluggish to return to idle, could be gummed up and needs cleaning.
If not dirty, I would still lean towards the TB though, since there are no codes popping up. Make sure the wiring is all go to the TB, has been know for broken wires, but again this would show a code. |
I'll look in to that , thank you
I definitely wouldn't just toss parts at it. You need to diagnose the issue. When you installed the scanner did you see what the throttle position was registering and if it was following the pedal or not?
Originally Posted by User Omega
(Post 1595154451)
I will read up on it and have a go at it this weekend Thanks Ps I'm new to using the tech2. I'm on a big learning curve, I am far more experienced with 70 model petrol engine technology |
I've never done it or if it's possible, but you maybe able to watch the throttle body work as someone else works the pedal and check the operation to see if it follows the input from the pedal. So if it's hanging up (TB) when the pedal is released quickly, that could give a clue.
You would have to have the ignition on and pull the TB tubing off, obviously. |
