C6, c6z abs computer, fuel tank senders
I have a new ABS/traction control (EBCM) an 08 Z06, may fit others
$300 I also have a pair of new fuel tank sending units for 06/07 and early 08 corvettes $75 each Used 08 z06 torque tube-$400 new ls2/3 water pump- $160 new stock c5, c6 crank pulley $50 new gm ls7 & ls3 clutch kit & flywheel $350 for both lightly Used ls7 lash caps $30 New gm ls7 rocker arms $80 used LS3 rocker arms and stands $80 used ls2,3,7 valley cover $70 |
Originally Posted by 454z06
(Post 1595159631)
$300 I also have a pair of new fuel tank sending units for 06/07 and early 08 corvettes $75 each Used 08 z06 torque tube-$400 new ls2/3 water pump- $160 new stock c5, c6 crank pulley $50 new gm ls7 & ls3 clutch kit & flywheel $350 for both lightly Used ls7 lash caps $30 New gm ls7 rocker arms $80 used LS3 rocker arms and stands $80 used ls2,3,7 valley cover $70 Will also PM |
