Tubular Front "A" Frames Are They Worth it?
I am thinking of buying a set for my 65. I am curious if you guys think they are worth the $.
I am looking for better handling so I can occasionally autocross. I currently am running Ride Tech adjustable shocks and stock springs which I was going to stay with instead of spending the extra money on coil overs. In the back I have a Muskingum Brake 330# composite spring with Ride Techs. I have been checking out Global West. Curious to get your feedback. |
Originally Posted by woodsdesign
(Post 1595204096)
I am looking for better handling so I can occasionally autocross. I currently am running Ride Tech adjustable shocks and stock springs which I was going to stay with instead of spending the extra money on coil overs. In the back I have a Muskingum Brake 330# composite spring with Ride Techs. I have been checking out Global West. Curious to get your feedback. Lou https://cimg7.ibsrv.net/gimg/www.cor...a7a56b1d84.jpg |
I am currently running Michelin Diamond Backs 215/70/R15 on Bolt on knock offs. I want to keep running that set up. It will mainly be street driven. I am looking for a performance upgrade.
1 Attachment(s)
I found out that if you want to run a 335 tire with 9 inches of backspacing on your C1 track car, you have to build your own. LOL Mock-up on the right, CM lower under construction on the left. I built the mock-up out of black pipe (actually 5 separate mock-ups) until I worked out all of the clearances I needed with full compression and 30 degrees of turn.
Pappy Attachment 48116882 |
