Need a "How to"
Ok guys and gals, I have an early 64 and need to remove the pinion mount from the differential.
The two front bolts are easy. The rear attachment is a long bolt that goes through the differential case. Attempting to remove it results in the bolt contacting the floor pan about halfway out. How do I get that bolt out without dropping the diff or raising the body? |
Short answer: you won't.
You can release the crossmember with the two hockey pucks and drop the diff. Other obvious parts need to be removed/disconnected first, like the spring. |
:iagree:
Try a long pry bar and see if you can pull the differential down and remove the bolt.
Originally Posted by MikeM
(Post 1595276592)
Originally Posted by Tmichaelson
(Post 1595277972)
Not sure if the 64' is the same configuration as my 66' but I disconnected both of the inner half shafts universals from the differential and then pulled down the front of the differential. The long bolt JUST cleared when removed. Read somewhere that an option is drilling a hole in the side of the jack compartment to remove the bolt.
Trying to avoid the "hole in the jack compartment" scenario...... |
Originally Posted by Subfixer
(Post 1595285329)
I can give that a try.
I would yield to the experience of others here, but I'm not loosening anything till the energy is released from that spring!
Originally Posted by pop23235
(Post 1595292083)
(Post 1595285329)
Trying to avoid the "hole in the jack compartment" scenario...... A while later I happened to be at a local Chevrolet dealer where I sourced all of my parts and asked if I could speak to their "Corvette" mechanic. A young guy not much older than myself came out and asked if he could help me. I asked him how he removed that same bolt. To which he remarked, "ah, there's a trick to it. First you have to drill a hole in the side of the jack compartment..." :D GUSTO |
