Fuel Pump/System Part #'s
I did a lot of research finding the correct parts to replace my fuel pump and I thought I would post my results here for others to benefit from. If something is not correct just let me know and I will make the corrections. You guys are always helping me so I thought I might try and return the favor. :flag:
Left Side A/C Delco MU1406 Sender w/ Level Sensor 2004-2006. A/C Delco MU2186 {#19302043} Includes Level Sensor; w/ Internal Strainer 2007-13. A/C Delco M10057 Sender Assembly 2003-13. pump only. Right Side A/C Delco M10014 {#19133425, 19149684, 19258630} GM 2004-06. Pump only. A/C Delco MU1892 {#19208205, 19258634} w/ Level Sensor; w/ Internal Strainer 2007-2008. A/C Delco MU1890 W/Level Sensor 2009-2013. Sensor Only A/C Delco SK1227 Right 2007-2013 {#19149683, 19207711}. A/C Delco SK1228 Left 2007-2013 {#19149686, 19207710}. A/C Delco SK1169 Right 2004-2006. A/C Delco SK1175 Left 2004-2006. fuel Line 2003-2013 A/C Delco 10337581 Right Auxiliary; INCLUDES O-RING SEAL IN CONNECTOR. A/C Delco 10337588 Auxiliary; PIPE ONLY center. A/C Delco 10337583 Left Auxiliary; INCLUDES O-RING SEALS IN CONNECTOR. A/C Delco TR7 {#25691383} RING 94mm Tank Opening Cam Lock Ring 2003-2013. A/C Delco G42 {#21008100} Auxiliary, 112.8MM OD X 5.4 THK 2003-2013. A/C Delco 16238399 Fuel Tank Pressure Sensor. Z06 2003-2008 A/C Delco M10014 {#19133425, 19149684, 19258630} Right side 2nd design Pump only 2003-2008. A/C Delco MU1892 {#19208205, 19258634} Includes Level Sensor; w/ Internal Strainer Right; Z06 Model 2007-2008. A/C Delco M10059 {#19149082, 19149687, M10053} Sender Assembly Z06 Model 2006-2013 left. Pump Only. A/C Delco MU1889 {#19207959} Includes Level Sensor; w/ Internal Strainer Left; Z06 Model 2007-2013. |
Good info. I just had to order a bunch of those parts...........
I have a standard, 2007 Vette. I've gotten the P2068 error code and my fuel gauge is not working...everything else regarding fuel is fine. The more I review things, it appears both tanks have pumps and gauge sending units but the P2068 would point to a failure in the passenger side unit and not the driver side unit.
In discussing this with the parts group at my local dealer, they wanted to know the VIN since they said the parts were "VIN specific". They gave me the following part numbers for complete units which included the fuel pump and fuel gauge sending unit (including float): Driver side: 10339515 Passenger side: 10356480 Either I have bad numbers or I am misreading those listed in your note since mine don't align with yours. Can you clarify....or am I getting smoke up my skirt from the dealer? |
Is anyone familiar with GM Part number 19354664? GMPartsdirect shows that it fits 2006-2008 Z06. I got this using my 2008 Z06 VIN. Understanding it can just be wrong I want to use the correct part number. I have an AC Delco M10057 and will use it or put another pump in it if usefull for my 2008 Z06. I do see the AC Delco M10059 as the current 2008 Z06 Left side Fuel Pump Assembly. AC Delco's site shows the M10057 for a 2013 7.0L. What is the difference between the AC Delco M10057 and the AC Delco M10059? Is it an old number, useful or not. I read the part numbers above and searched the entire forum but very little comes up on these numbers.
