I see very few modern cars with really bad oil leaks or even smoking much...
And you don't see that black streak down the center of the lanes nowadays... But then my motorcycle days are over so I'm unaffected. |
Here's one for all you smog historians. Required by the State of California. Was on a 1961 Corvette I purchased that had a harness short in the early 1980's, and it was parked. Did more harm than good.
https://cimg9.ibsrv.net/gimg/www.cor...f213e2227c.jpg |
Originally Posted by Frankie the Fink
(Post 1595335983)
(Post 1595335983)
I have always said the best two things the government forced on the auto companies were emissions and safety.
You're lucky if you see a car over 8 years old on the road in central Florida between the tourists, the rentals, the lease cars and the yuppies I guess.
Streets are pretty clean and most drivers can't even stay in the center of the lane (texting), let alone make an oil slick there... |
Originally Posted by dplotkin
(Post 1595333651)
Cadillac's maintenance regimen in pre-PCV days was to annually pull the oil pan & clean it out. Dan
a valve cover and being amazed by the amount of black gunk inside. It looked as if the car had never had an oil change. |
Originally Posted by Randy G.
(Post 1595336030)
You see the streak in some of the more economically challenged areas of L.A. .
I used to commute into Southgate via Imperial and Firestone from north OC on my Motorcycle on nice days, back when i lived in SoCal. Any freeway was iffy in the center, also. PHX is bad also, there are a lot of unmaintained vehicles, and it doesn't rain that often, so when it does, it can get pretty greasy. Doug |
Originally Posted by AZDoug
(Post 1595339439)
Yes.
I used to commute into Southgate via Imperial and Firestone from north OC on my Motorcycle on nice days, back when i lived in SoCal. Any freeway was iffy in the center, also. PHX is bad also, there are a lot of unmaintained vehicles, and it doesn't rain that often, so when it does, it can get pretty greasy. Doug . |
(Post 1595335983)
I see very few modern cars with really bad oil leaks...
If you parked a Triumph or MG and it left no oil puddle, that meant it was out of oil. It was easier to look under the car than to check the dipstick. Some folks liked to say that it was self-installing undercoating as you drove. :lol: |
Originally Posted by MrPandy
(Post 1595342086)
That's mostly due to the demise of the domestic British car industry :yesnod:
After dealing with everything from Renaults to Porches to the American "Big Three" back in the 60s I can tell you that they all leaked given enough time or abuse..
On the Brit-mobiles I worried much more about the wiring. Lucas was my personal favorite... |
1 Attachment(s)
No intention of hijacking this thread but curious whether I could share or tee off of the WCFB threaded connection that goes to the windshield washer canister?
2 Attachment(s)
Yes. You can "T" into the back of the carb any way you can think of...on this original 63 carb once side of the brass fitting is for a power brake hose and the other is to screw in the PCV valve...
For my 61 dual quad car (second pic) I 'rolled my own' connector. |
Thanks FTF. I'm going to figure out how to "roll my own" as well and get rid of my road draft tube. I always wondered why my oil turned so dark when only driving a few miles after a fresh oil change. I want my honey back!
(Post 1595326204)
Its the PCV valve (Positive Crankcase Ventilation) system...
You will need a PCV valve, a right hand spark plug loom from a 63 car (repros are around) to hold the plug wires when the road draft tube is removed, a vented oil filler cap and a means to convert the road draft tube to support a pipe or hose attachment. You will also need the rear base of the carb drilled to accept the brass fitting. Search for RPO-242 on here and/or refer to your AIM (Assembly Instruction Manual). If you can't find the crankcase hole conversion fitting shown (expensive but Paragon had them) a grommet with a hole as used in 63 works just as well. |
No, the fittings are all the same, pretty much. On my '61, I simply used a rubber grommet and it fit in the hole in the block nicely. Plugged the PCV into that and ran it to the back of the REAR carb, for a cleaner install.
Just do an ebay search for "GM PCV Conversion kit" and you'll come up with a dozen...any will work as the road draft tube hole is generic across GM cars and this is just one example (although the PCV valve may not be optimal - you'll have to figure that out):
http://www.ebay.com/itm/55-56-57-Che...5Tj-aV&vxp=mtr |
Originally Posted by GTOguy
(Post 1595345384)
Originally Posted by treh1
(Post 1595345013)
