How to disable Low Tire Pressure Warning System in 96 Corvette with Run flats
How do you disable the Low Tire Pressure Warning system option on a 1996 Corvette
Originally Posted by LUDS 96
(Post 1595329482)
Disconnect of the module I believe will require dash pad removal. I don't believe option content control was ever added to a C4 BCM/CCM but if it were it would have been likely a '96 only feature. |
(Post 1595329482)
what is the option code for run flats ? i have a maxed out CE LT4 but don't think car has this. is this even possible ?
code is : uj6 , not on my CE, that makes me :woohoo:
Originally Posted by johno504
(Post 1595375353)
my bad, uj6 is low pressure warning, and i'm still :woohoo: one less pain the ass to deal with.
Ltpws
Originally Posted by milsurpman
(Post 1595345151)
Remove connector from module.
