Driver Mode switch
Could someone point me to a resource that will explain all of the options using the Driver Mode switch on the center console. I get the Wet/Tour/Sport/Track changes. But I think there are sub menus below this. Is this true?
Also what about turning the nanny's off? Can I do this? Thanks!! |
Rotate that knob to TRack and click your heels twice (or push the button twice) and you may not be in Kansas but you'll be in the hidden sub-menu. Two nannies on car. Traction control and stability control. Don't shut them all off unless you have a lot of insurance, or are a professional race car driver, or filthy rich. Corvettes are light and that is a lot of power to just turn loose as that is how we get to see pictures of wrecked Corvettes which breaks our hearts.
If you have a Z51 or above w/ MSRC, pressing the center console button quickly twice puts you into the Track PTM (performance traction management) menu, which gives you this. Once you're in this menu, rotating the dial left or right moves you between PTM Wet and PTM Race. Pressing the button once again, puts you back into the standard menu, Weather to Track
https://cimg5.ibsrv.net/gimg/www.cor...a1b1d4f1e4.png |
Originally Posted by Foosh
(Post 1595344128)
https://cimg5.ibsrv.net/gimg/www.cor...a1b1d4f1e4.png These comments are very helpful. Thank you. |
FWIW, I drive in Track mode 90% of the time.
PTM is GM's acronym for performance traction management. It was really designed for various conditions and skill levels on a race track, but PTM/Wet and PTM/Dry are very good street settings. PTM Race is essentially all "nannies" off, and is not recommended unless you are on a race track, and have a lot of experience.
Even world class race cars these days use traction and stability control. The C7R in the GTLM class has it. |
(Post 1595344159)
The chart tells you what systems changes occur when selecting PTM Wet, Dry, Sport1, Sport2, or Race. As I said, once in the PTM menu, the same console dial rotates between the PTM modes, just as it does the standard modes.
Again, you're talking about standard Track mode. Track PTM is different. Look at the Track PTM mode chart above and pay particular attention to the MSRC settings.
MRC + Z51 = One Hell of a Combination.
After many manual transmission cars I have been shocked at how much I enjoy shifting with the paddles in standard Track mode.
I can well see the differences as one moves into these lower menus. |
Originally Posted by TNSQUIRE
(Post 1595344200)
If you have msrc be careful using Track mode on the streets. It is not recommended and may cause damage to your car.
In standard Track mode, MSRC is in the stiffest setting, which is indeed very stiff. Like all cars running very low profile tires, wheel damage is real possibility on road surfaces in poor condition, and a pothole can be a death sentence for low profile tire/wheel combos. That's even more likely w/ MSRC in full firm mode (Track), but it can also happen any any mode.
In Track PTM, the MSRC setting varies per the chart published above. Thus, in Track PTM/Wet, you're no more likely to have damage than when you're driving in Tour mode because the MSRC is in Tour mode. In Track PTM/Dry MSRC is in Sport mode. |
I never turned mine off when it was stock.Now with 700 hp I wouldn't turn it off on A bet.
It can get away from you faster than your reflexes have A chance to compensate. |
"pressing the center console button quickly twice puts you into the Track PTM (performance traction management) menu"
Do you have to be in Track mode before you press the button twice to access the PTM sub-menus? |
Yes
(Post 1595344171)
Thanks again. I will play with this tomorrow.
Bill |
Bill's explanation above is a good one.
The whole idea of PTM (using TC, DSC, and the eLSD) is to match the car and conditions to the available grip. A lot of people seem to think that's going to make them go slower, but I'll wager a sizable sum it's the opposite. If you're sliding, you're not going as fast as you could be. |
Wow. This has been very informative. I went out earlier today with the wife. I really haven't played with it much but I did switch thru the modes. In the morning I hope to take a ride alone and try the first couple of modes.
