Need a 340lph fuel pump - Reco's?
Need an in tank 340lph pump, as my racetronix 255lph isn't up to the task.
Anyone got any reco's? |
you can use a walbro 450 if you don't mind modifying the bucket a little bit... it's nothing crazy, you just need to cut the bottom out for it to fit... if you have a side loading pump you would probably need a different sock filter that would lay on the bottom of the tank like the factory pump... if you have a top loading pump then the filter supplied with the 450 will be fine
think lingenfelter makes an 340 or maybe its a 380 lph
