Proper Wiper Blades on 86
Can someone give me the proper wiper blade sizes on an 86? I believe one is smaller than the other. Thank You.
The correct answer for an 86 are 2 low profile 18" blades.
The best way to go are 2 Trico 20-2's. Ask me how I know. |
Originally Posted by Cjunkie
(Post 1595375547)
Probably most have, they bought some that were 'supposedly' for an 86 and hit the hood. I happened to have the same situation where I had the dealership replace the blades while having some work done. You'd expect them to have the right ones, they didn't. I ended up getting some from RockAuto, NAPA label but were right for the car.
Best suggestion I can give, take one of your old ones to wherever you get your blades and compare them. there are 2 different hole sizes put the mount isn't the same on all the blades. |
Originally Posted by hcbph
(Post 1596581295)
Originally Posted by Mikeceli
(Post 1596579647)
Old thread , but how do you know?
If you wanted a shorter blade a 19-2 I'd think could work well. I've never tried them but I believe I have a friend that does use them. He's not local anymore |
(Post 1595375547)
