Help. Eaton tru trak.
95 c4 Dana 44. Bought a eaton tru trak. Cannot get the snap rings on the axles. There seems to be not enough room to fit the snap rings over the axles inside the tru trak. Help please. Thanks.
Originally Posted by Tinman1118
(Post 1595473893)
Another thing is that there are different thickness retaining rings for the D44.... They are how you control stub shaft end play..... Your current retaining rings may be too thick to work in the new Tru Trac. You can figure this out by sliding the stub shaft in and measuring the amount of the shafts retaining groove is sticking through the side gear with feeler gauges and comparing that measurement with how thick your retaining ring is. Will |
I usually have the snap ring expanded inside the case with the pliers, then slid the axle into the ring.
Originally Posted by RichS
(Post 1595474162)
I had to use thinner snap rings on the side shafts when I switched to the Tru-Trac. Got them from Tom's
http://tomsdifferentials.com/2011catalog/Pages25-28.pdf BTW - helps a lot to have a heavy-duty pair of snap ring pliers. |
I get what you all are saying. I mean the snap ring won't even sit down into the housing fully.
..... Pics ? .....
(Post 1595479851)
