Radio head unit upgrade questions
Happy Labour Day 2017 my Fellow Corvette Brothers and sisters!
Looking to upgrade the head unit and speakers in my Vette. I want to install an all-in-one double din unit. Will any standard size double din unit fit? What size unit and screen is everyone using? I would appreciate speaker suggestions as well. I am not looking for anything crazy just replacing the four that are in the car. The car came with an after market radio that who ever installed it did a lousy job. I am getting all sorts of feed back and cracking noises from the passenger rear. I assume I will have to re-wire it. |
Is it Bose or non Bose?
Wonder if the previous owner tried to use the OEM Bose speakers? Each Bose speaker had their own amps and that could be part of the problem you are hearing.
You can find lots of good suggestions and ideas in the Audio/Electronics section of the Forum. :cheers: |
Originally Posted by aklim
(Post 1595503401)
I bought speaker enclosures for NON Bose and out in speakers that fit. Wire ran from the head unit to the speaker.
Any of the double DINs that do not have a moving face should work. I have a Pioneer AVH-4200NEX that has a removable face and can tilt. The opening isn't quite large enough, especially due to the rounded corners around the bezel. I had to grind a trim a lot of plastic in order to get it to work, but in the end, it looks good (as long as the face plate is there :ack:) and works perfectly.
https://cimg3.ibsrv.net/gimg/www.cor...2645ed1044.jpg https://cimg5.ibsrv.net/gimg/www.cor...6813a14f38.jpg |
The noises you are hearing could be an amplifier in the speaker having failed.
Originally Posted by JimLentz
(Post 1595510134)
If the early C4 in your avatar picture is what you have the cutout for the radio is 1.5 din. You can put a double din in with modification.
https://cimg1.ibsrv.net/gimg/www.cor...41250c5569.jpg |
Originally Posted by Dt86
(Post 1595540780)
https://cimg1.ibsrv.net/gimg/www.cor...41250c5569.jpg Dave |
Originally Posted by chief85vette
(Post 1595564886)
Thinking of doing thins in my 85 but everyone is vague on "modification". Is that trim plate mods or internal mounting mods? Yours looks great. Just what I was looking at
Dave |
(Post 1595540780)
Originally Posted by The Thomas J
(Post 1595565129)
WOW! That looks amazing. The color of the display matches the dash gauges.
If I didn't know C4's I would have said that was the stock stereo (almost), good job on the install! |
Originally Posted by c4cruiser
(Post 1595503631)
You can find lots of good suggestions and ideas in the Audio/Electronics section of the Forum. :cheers: The amps tend to be the more common culprit, with the Bose system each speaker has it's own amplifier that is behind speaker if you remove them. The majority of the time its the capacitors are no longer working to their specified rating and just need to be replaced. A lot of older capacitors from mid-90s down have limited life spans. |
would this work
(Post 1595565049)
The bezel you can buy. There's a vendor on here that used to make them. I think the name is double d mods?? That or my mind is in the gutter. Lol. I cut mine then filled and shaped it with a poly filler. The other piece that needs modification is the inner bracket inside the dash behind the radio. It's formed to fit the 1.5 din so you need to trim it so that the double din headunit will fit inside. For easy wiring I purchased the metra wiring harness so that the headunit would just plug into the factory harness. Be warned, space to cram the wiring is tight. Overall it wasn't that bad of a project but the fit and finish aspect of it is the time consuming part of it.
