Qa1 single adjustable settings for the dragstrip?
It's a auto with 28 tall slicks and I also just received my pfadt drag bar
Originally Posted by megac5
(Post 1595527236)
Have no idea on shock settings, stock suspension here. |
Originally Posted by hot_wheels
(Post 1595530336)
what size stall are you using?
I called qa1 this morning and he said to set the front soft to 1-2 clicks and the rear to almost its stiffest setting. Said it will raise the front and stop the rear from hardly squatting or rebounding so it will plant and drive the tires into the track
Tested the car tonight with a stiffer rear and she hooked pretty good on the crappy track! Pretty sure she would dead hook on a good prep track
