90mm TB
I have an 03 z06 and am wanting to upgrade to a 90mm intake which would obviously require a 90mm TB. I know from reading other threads that an ls2 TB will work fine as long as you get the adapter for the electrical cable. My question is would a set up with an ls3 TB also work, still using a cable adapter because the plugs are different, because from searching ls3 TBs are much more available and cheaper to find vs an ls2 TB.
Take a read thru this thread. Most who have tried to use an LS3 have not been able to get it to work. If the LS3 did work then we'd all be using them. However, a slight glimmer of hope in the following thread. https://www.corvetteforum.com/forums...y-on-a-c5.html
Originally Posted by CactusCat
(Post 1595771422)
