Known C4 issues
As I am progressing with my 1990 vette I am finding little things that are not working. So far we have bad injectors, cooling fans/relay not working, LCD wont display, daylight sensor isn't working and the door switches for the rear hatch don't work. The dash and weatherstripping also need work from sun exposure.
I am about to order new injectors and know they sell a repair kit for the LCD and the light detector. I have to test to see if the fan motors work at all and will take care of that on my next day off. Are there any other gremlins that are common for a C4 I can try to track down before I get my self stranded away from home? |
Fuel pumps & relays
Steering rack gets morning sickness Antenna usually is broken by now Bose stereo amp issues Driver seat bolsters wear 1/2 shaft U Joint Wheel Bearing Assemblies Headlight motor gears wear out power seat lumbar bladders That said the stuff you mention is pretty common stuff... |
I'd add that pesky problem where the hood release quits working, might want to see about installing the emergency release for that early, it's a cheap repair if I recall correctly
If you can get spare abs sensors I'd get them, nobody really makes them anymore that I've found The door panels get wonky, alot of C4's will have their panels start hanging away from the door and leaving a giant gap between window and panel The visors tend to get floppy eared, my fabric has started disintegrating There's a couple more that I can't remember, but I think 81c3 got most of them. Most of the problems you're having are pretty common If you're getting in to change the fans, I'd recommend checking out the radiator. Often times it can get clogged with any grass, dirt or debris it sucks up off the ground, and that'll kill your temps. How long have you had her? Any maintenance records for her to reference? |
U-joints
bushings hubs steering wheel wobble tape deck / cd player issues head gaskets depending on year fuel injectors shocks weatherstripping vats heater core abs on some years automatic 3-4 clutch pack windows go up slower on earlier cars dash isssues |
Well the all the parts of the fuel system have been replaced or are on order so fixes that issue. I will keep an eye open for the rest of the mentioned issues. Thankfully I wont suffer the same issue a friend of mine did with the 3-4 clutches, kinda hard in a ZF. I will look into the hood release pretty soon.
Originally Posted by Space387
(Post 1595790902)
These were not built to last. They were built with mostly off the shelf gm parts though so that helps. Except the clutch for the zf is an issue for some people. |
The clutch dose make a horrible racket when engaged but not under load. I suspect it is either the springs in the friction plate or the throw out bearing. With the clutch pedal depressed or while driving there is no noise and there is no noticable slop in the drive line. On the note of a clutch is it the same pull type as what you get on an LT1 or is it the conventional push type?
And don't forget the "Air Bag" light problem on the 1990 models.
Originally Posted by jts90vette
(Post 1595791166)
(Post 1595791315)
Is it just the light comes on for no reason? I have had the car up and running( be it poorly) and get no alert lights.
(Post 1595789944)
Originally Posted by pologreen1
(Post 1595791010)
A zf is not bullet proof. Very costly to fix when they go. Hopefully it's good.
Originally Posted by aklim
(Post 1595795695)
Injectors are probably Multecs which belong in a landfill or as a trap shooting target. Why get new when you can get Bosch 3 rebuilt? Stock size is common and under $200
(Post 1595799393)
Actualy they where replaced with what looks to be the same as what came in the LT1 engines ( Rochester I think?) The repair bill was 1300 just for the injectors back in 2004. So glad I didn't pay for that. I am actually picking up a set of these. I know cheep ebay but for the purpose of getting up and running why not give them a try? I have had surprisingly good luck with ebay parts as of late and if they last me 6 months to a year so I can troubleshoot everything else they where worth the money.
Thats fine. I have bought these kind of parts with low expectations before and got great results for a fraction of the cost. And with injectors the only "rebuild" you can do is pull the filters, drop it in a sonic cleaner and replace the o-rings. They are designed to never be opened once assembled.
Neither here non there until I get them in anyway, but thanks for all the other things to look at while I get this thing ready for a first distance drive. Quick question, how high on the dash is the trigger point for the coolant fans? When I had the car running before it got pretty warm but the fans never kicked on. I have checked the fans and relays all work, I can even trigger them from the PCM plug. |
(Post 1595803890)
Originally Posted by 81c3
(Post 1595804505)
226* to 230* for the most part...
