starter
I have a 327 motor (62-65) and a 350 turbo trans. I have a 168 tooth flywheel. I need a starter to put in as I bought this from someone and it did not have a starter. what will fit?
Totally wrong forum to ask this question but since I'm a hell of a nice guy, I looked it up for you on Google. http://www.chevytalk.org/fusionbb/sh...hp?tid/171683/ You're welcome! :cool::cool:
starter
Originally Posted by CactusCat
(Post 1595833200)
thanks for being such a nice guy... Nick |
NP. You might have some luck in the C2, C3 or C4 forums as that motor is more inline with what they use. C5s use the LS1 engine and the older small blocks are very seldom used in a C5 or newer simply because the LS series make really good HP for cheap. You might have some luck asking this same question in one of the older model forums. GL with your solution. :cool::cool:
The c2 flywheel was the 153 tooth version and the 350 block went to the 168 tooth version, the take a different starter gear to work. You more than likely are ordering the C2 starter and not the C3 version. If you are going to get the smaller flywheel, be sure to order the L88 one as it is 14lb nodular iron vs the steel one at 30lb. HTH
Which way is it out, front to back or gear mesh? How much over 1/8th inch is it?
A starter from a mid 90's pickup would be a good choice. It's smaller and lighter. |
Originally Posted by lionelhutz
(Post 1595848523)
A starter from a mid 90's pickup would be a good choice. It's smaller and lighter. They say you can put in an eight inch drill bit and if it fits fairly tight its good. but I could fit 2 of them in there. |
