2006 Z06 - 49k Miles - $36K
2006 Corvette Z06 (2LZ)
VIN: 1G1YY268E65121180 Velocity Yellow Miles: 49,801 Miles on new engine: <5K Miles since purchased: approximately 25K Purchased in 2010 as second owner Clean Carfax Illinois registered as of October 2017 (previously had CA plates) PRICE: $33,000 Contact Info: Email: icrashevos@gmail.com Private Messages welcome as well, though response time may be delayed History: Traded my Mitsubishi Lancer Evolution IX MR into Carmax and purchased the Z06 in May of 2010. Intentions at the time were just ownership, and later figuring out what I’d want to do with the car. Shortly after owning the car, I attended a private Track Day at Thunderhill Raceway. I was and still am an inexperienced driver, but never really pushed the car to its’ limit. Shortly after the track day, I had the Halltech MF102 intake installed and tuned as it was. Later, I decided I wanted to have a more track oriented car, but knew there were some issues with the engine, so I decided to do a new engine entirely, and purchased a long block from Texas-Speed and Performance. I purchased PRC265CC Heads, a RPS Carbon/Organic clutch, and a LS7R cam, an electric water pump, PFADT motor mounts, and a new new exhaust.. While the engine was being installed, I threw on a set of B&B PRT Bullets, eliminating the stock mufflers completely. The car sounded absolutely fantastic, but due to the short fingers on the clutch, massive-flowing heads, and a mismatched LS7R (surging) cam, it was a nightmare to drive. It surged from idle to about 2,500 RPM in this setup, and I just hated driving it. I later swapped down to a custom Cam from Rick @ Synergy, which made the car much more tolerable. After discovering a head issue with the PRC265CC Heads from TSP, I decided to have the motor redone completely at Synergy Motorsports, and this time it would be done right. I asked Rick to re-use any good parts that met his standards and buy new products to fit my request. At this time, I decided to keep the aluminum short block instead of going with a 454LSx, as tracking the car proved to be much more fun, and keeping the weight down was paramount. Rick refreshed the block, used a set of stock ported heads provided by his shop, and purchased new internals, as seen in the engine build below. The only items carried over were the Manley Crank and Rods from the previous build. During this time, and with advice from Rick, I decided to swap back to a stock LS7 clutch, as it holds the power just fine for road racing and has drivability. It’s a little light for my taste, but it’s much easier to drive across the board. The car has seen the drag strip a handful of times, and I have never launched it over 2,800 RPM. It’s never seen a set of slicks, or even a burnout during my ownership (hard to believe, I know). Rick spec’d a custom cam that matched his heads and sorted my car. We put on Kooks headers and put my stock mufflers back on, which was nice having the muffler switch back to eliminate drone. It opens up at 4K RPM regardless, but it’s drivable well below that RPM for daily use. The car had a 95% Detail and CQuartz application done by Jeff @ Immaculate Reflections while still in California. I later moved to Belleville, IL, and had to have the Vette shipped at a later date. It was quite dirty from open trailering, and with my new purchase of an Ariel Atom 3S, I don’t have a need nor room for the Z06. I had it shipped out here in October 2016, and subsequently had it detailed to another 95% correction with a transferable 5 year Ceramic Pro application by Matt @ St. Louis Auto Detail late 2016. It has remained in my garage, and was on a brief consignment at Gateway Classic Cars while I was out of the country. The car now currently resides in my garage, and will remain indoors until the car is sold. My intentions with this car prior to selling it were to have a very streetable car that could be driven to the track or trailered to farther tracks for HPDEs. It had a Corbeau FX1 Pro seat with a Crow 6 Point harness installed for three of the four total track days under my ownership, which as been removed and the stock seat is back in, with all power adjustability. I’ve been pretty particular to this car, and have kept it clean between details and always garaged, save for maybe 15 total nights since 2010. It drives as stock as you can get with 563 RWHP and solid motor mounts, and is a car I’ll definitely miss once sold. Modifications: • Engine - Fully built Aluminum LS7 by Rick at Synergy Motorsports in Livermore, California. - Wiseco Pistons, 4.130 Bore - Manley crank and rods (from previous build) - Clevite bearings - LS7 head gaskets, .045 thickness - Final compression is 11.7 - Stock Heads Ported by Synergy Motorsports - BTR Springs - Johnson Lifters - LS9 Oil pump with an .080 shim - 7.750 Pushrods - 238/248 Custom Cam 113+3 - Meziere LS1 Electric Water Pump - FAST 102mm Intake Manifold (Painted at Synergy Motorsports) - Halltech MF102 Intake - Baffled oil pan • Exhaust - Kooks 1-7/8” Headers & 3” mid pipe into stock mufflers (muffler mod included) • Drivetrain - PFADT Motor and Transmission mounts - Stock LS7 Clutch (replaced a RPS organic/carbon clutch that was a nightmare to drive) • Suspension - Lowered on stock bolts • Brakes, Wheels, & Tires (<5K miles on brakes and rotors) - Front: DBA 4K Rotors - Front Pads: Carbotech XP8 - Rear: DBA Blanks - Rear Pads: Carbotech XP8 - Stock Z06 Replica Wheels - Toyo R888 tires (stock sizes) - Speed Bleeders - Braided Stainless Brake Lines • Interior - Hydro-dipped carbon fiber pieces - MGW Short-throw Shifter - Harness Bar - Additional heat shielding installed under carpets in cockpit - Driver seat was replaced with a Corbeau FX1 Pro for nearly the entire duration of ownership • Exterior - 35% Exterior tint on side & rear windows - Halltech Carbon Fiber intake insert - Black Housing OEM Headlights included (never installed) - Removable Thunderhill 5-Mile black sticker behind driver door on rear window - St. Louis Auto Detail 5 Year Ceramic Pro detail & application, including warranty certificate, done in late 2016 Miscellaneous: - Comes with both Keyfobs - Original Leather-bound owners manual & supplement material - Roof recall completed (roof & halo painted black during this time) - No active recalls at this time - “Light” track alignment, all corners set at 1.5* Camber to not destroy tires on the street - Dyno’d at 563 RWHP, 522 TQ on 91octane @ Synergy Motorsports Areas of “concern” (me nitpicking pretty much): - Tighten shifter knob screw (Shifter has slight play, but is still seated) - Add foam padding between Gauge Cluster and Dashboard on top (slight rattling from solid motor mounts causes annoying vibration at idle) - Driver speaker wire is intermittent (rarely used) - Muffler Mod could be redone, rattling heard at idle - New set of wheels and tires for daily use Pictures can be viewed at the following link. I’ve included pictures of when I had a brief off-road stint, and pictures show that the car has been taken care of. https://icrashevos.imgur.com/ https://cimg5.ibsrv.net/gimg/www.cor...0e68eabd83.jpg https://cimg6.ibsrv.net/gimg/www.cor...b4d30e90bb.jpg https://cimg7.ibsrv.net/gimg/www.cor...e436179111.jpg https://cimg8.ibsrv.net/gimg/www.cor...7f0cf87b46.jpg https://cimg9.ibsrv.net/gimg/www.cor...964e832b8c.jpg https://cimg0.ibsrv.net/gimg/www.cor...d45aea4625.jpg |
Ttt
ttt
Good luck with the sale buddy! Car is looking sharp!
Just listed mine for sale too. |
Originally Posted by GoFast908Z
(Post 1595927810)
Just listed mine for sale too. ** Price Reduced ** |
Car is still for sale.
ttt
Still for sale, Asking $36K.
thats a LOT of car for 36k!
Damn right it is! Thanks for the bump :)
ttt
Price reduced.
Car starts up immediately and is ready to sell. |
Price reduced. Car mileage will go up slightly to keep everything in good working order.
Ttt |
ttt
