Engine issue with my '68 :(
Just took the Vette out for a spin.. On my way home, I heard a backfire from the drivers side exhaust and the car would die.. It would start back up but refuses to idle. Was able to drive the car home but it feels like it's running on 6 or 7 cylinders and will not idle.. There is no smoke from the exhaust and oil pressure is good and stable.. I was thinking that it may be a valve spring issue?? I hope that it's nothing on the bottom end..
Any suggestions where to start? I guess pulling off the valve covers and checking the springs may be a good start. Engine only has about 10k miles on it since rebuild by the previous owner.. 10 years ago but only 10k miles on the rebuild.. |
Check the the easy stuff first: look at the points or electronic ignition module if so equipped under the distributor cap.
Valvespring or headgasket or maybe you have worn down the camshaft?
Would start and removing the valve covers and feel for excessive play in the valvetrain |
does it crank at the same speed, or faster. if timing jumped a couple f teeth, it'll run but be weak. and with a lot less compression, you will hear it cranking faster on the starter. pull valve covers and watch valves while cranking for 1 or 2 not moving. then bump starter till #1 exh just closing and #1 intake just opening and timing mark should be right around TDC. quickie valve timing check.
Sounds like the fire went out on one plug. I'm with Chapter 2--- check your ignition system and plug wires first. Maybe you shorted a plug wire on a manifold.
(Post 1595915102)
Originally Posted by Chapter2
(Post 1595915005)
Originally Posted by stingraymaniac
(Post 1595915008)
Would start and removing the valve covers and feel for excessive play in the valvetrain Not sure when I will get to start looking at it.. Kinda busy right now.. |
Originally Posted by stumpshot
(Post 1595915123)
I just hope that it's nothing on the bottom end.. I don't think so but nothing is impossible.. Good thing is that the oil pressure is good.. indicating no issues with bearings.. |
What engine? If it is a bbc with Qjet I'd check the base gasket. Everybody leaves out the metal plate and eventually the paper burns through - making a huge lean condition below 1500. Above that it runs fine. I know - this happened to me
Originally Posted by 68notray
(Post 1595916075)
Mine started to sound like a boat, I had blown the head gasket between the cylinders, no smoke from the engine just a popping out of the right exhaust
Your running a Holley and the engine backfired. Did you blow the carb power valve?
Diagnosing over the internet is impossible. It could be a dozen things. At best you could post a video but until you start pulling parts off to inspect its just a guess.
(Post 1595917270)
Originally Posted by Kim72
(Post 1595917453)
Originally Posted by Dynra Rockets
(Post 1595917501)
What is showing on a vacuum gauge?
What are the results of a compression test? What are the results of a leak down test? What happens when you spray carb cleaner around the carb and intake manifold gaskets? |
A blown power valve will usually exhibit black smoke out the exhaust from the mega-rich mixture. I'm still betting on an ignition issue.
(Post 1595917806)
