Cat delete pipes w/stock headers
I have a Borla O/R X and am looking to delete the primaries w/o changing the headers. Does Borla or anyone else make anything?
Originally Posted by MarkRacerX
(Post 1595936461)
Originally Posted by TorchZ51
(Post 1595937009)
Yikes! They sure are proud of those @ $800!
Originally Posted by timmyZ06
(Post 1595942068)
mind as well sell the Xpipe and put that 800 toward headers at this point!
A car with headers should be tuned and there goes the warranty. A car with the cat deletes doesn't need a tune. If you look through the thread, there is a lot of welding and fabrication that goes into the cat deletes. I'm just an observer and have no dog in the fight.
Originally Posted by 383vett
(Post 1595959707)
I think it being an easier swap option of cat deletes vs Headers in event you need to go to stock for those not doing pulley / having a tune, just looking at simple mods for good gains as they're said to be pretty good and not too spendy!
AFE has a pretty good Black Friday deal on their cat pipes.
https://afepower.com/afe-power-48-34...nnection-pipes Catless for $599, HFC for $879. |
(Post 1595959707)
One with headers would gain the best performance if tuned, but there are a couple header options that will allow you to install them without needing to tune out a CEL. |
AFAIK the only headers you can install w/o a tune are shorties. If you drop all 4 CATs, you will drop a code. If you tune out the CAT codes, your warranty is hosed with the ECM tune.
You can delete the rear CATs w/o a tune and not toss a code as they are not monitored like the front ones are. In the future, after my extended warranty is done, I will consider LTs, no CATs and a tune. ONLY when I quit the warranty path. Elmer |
Originally Posted by eboggs_jkvl
(Post 1596036295)
Originally Posted by lakemg
(Post 1596036508)
Elmer - I've had great success with the Kooks 1 7/8" LTs + Kooks Green cats + Kooks x-pipe with NPP mufflers. I have no CEL and I have not tuned it. I'll eventually tune it when out of warranty, but for now, I'm leaving it as is because I primarily just wanted louder/more aggressive exhaust. This is the only mod to my car. I know of a couple other guys on here who did get a CEL with this setup, but they were also running aftermarket cold air intakes/air filters. My air intake is still totally stock right down to the original air filter.
Buy a lottery ticket! You're walking on water! :D I've never seen LTs not toss a code, maybe because I don't keep CATs when I do LTs. Elmer |
(Post 1596036519)
Elmer |
