Good results today!
https://cimg2.ibsrv.net/gimg/www.cor...7fd2622c6a.jpg
After trial and error, learning and many different parts I can finally say I hit my goal. TF cast 220's, BTR stage 4 and Dorman LS2 intake. Uncorrected numbers were 472whp and 430wtq but that's just cause it's cold here in MN, haha. |
Looks good, the trick flows make good power! What cc are they?
Those dyno dynamic dyno's are a load bearing dyno and can read low like a mustang dyno depending on how their calibrated so I wouldn't be surprised if it matched your sae numbers of around 470 on a dyno jet |
64cc chambers
Impressive. I guess all the power is in the heads.
Originally Posted by Efx
(Post 1595956464)
Does power fall of at 6500 or did they stop the pull?
He stopped there. He asked if I wanted to go higher for more power band but I wasn't sure what to go to. Or if the stock bottom end can take it.
Originally Posted by 99blkfrc99
(Post 1595969138)
Peaked @ 6500. That's what I shift at anyway.
(Post 1595970701)
Originally Posted by Scotty2000SS
(Post 1595971845)
Sweet. Bet you’d pick up quite a bit in the 1/4 shifting higher.
(Post 1595973605)
thanks for the tip. Have you hit the track again recently?
Cool build!
