C4 Drop Spindles
I don't know if any one makes drop spindles for C4 cars or if they did if they are still around?
I have a 91 ZR1 I would like to lower. Thanks |
Originally Posted by danvan1
(Post 1595963133)
I hope you fail in this endeavor.
Geeze awfully harsh for a simple question guys. At least he is asking a legit question unlike another person on this forum.
Originally Posted by Space387
(Post 1595964054)
Originally Posted by Amotoxracer
(Post 1595964144)
Might as well put one of those big gay fins on the back ...
Originally Posted by SR71!
(Post 1595964218)
You mean like the new ZR1 has:blueangel::hide::D
(Post 1595964054)
Originally Posted by WVZR-1
(Post 1595964468)
I understand what a "drop spindle" is and I assumed the OP does also, thought the a short and direct answer should be understood by the OP and I doubt it offended him!
(Post 1595964468)
(Post 1595963249)
Originally Posted by 383vett
(Post 1595967548)
Not sure why the hostility for a legitimate question.
If your going to build a low rider then start with an impala ... |
There is a very good reason to lower the spindle verse just lower the spring mount point, you maintain suspension geometry if done right. Now we never heard from the OP how MUCH he wants to lower his car.
Let's all just take a breather and see how much he wants to ruin... ahem, lower his Z before jumping down his throat. |
I guess I am just curious what the drop rate would be.
How low do you plan to go? Many people claim their C4 is low enough or even too low factory for their taste. There are some that lower different ways, and some naturally get lowered based on performance replacement springs. Unless this is going to be parked for car shows... a slammed c4 will slam in to everything. if you want crazy low stuff or lower than you see in a typical lowered c4 air bags would be the answer IMO. |
There is a 40 dollar or so kit available that includes the new front suspension wedges and bolts for the rear to drop an inch and a half. That's about as low as you can go without running into real issues.
Dropped spindles are available for C5, C6 and C7 Corvettes to maintain proper suspension geometry on a lowered car. https://www.corvetteforum.com/forums...p-spindle.html
The op was no doubt thinking among those lines. |
Wow I never expected to see such negative responses pattern day trader you sir are a classic Douchebag it is my car and I will do with it as I please.
For the rest thank you for the information, I have had a bunch of C4 Corvettes and have lowered every one of them I am a competitive autocrosser and lowering helps make them fast I thought since the ZR1 is a bit of a special car I would try to lower it the right way. Thanks Dan |
(Post 1595969364)
Dan |
Lowering one is not so hard lots do it here, the 4x4 stance they have could use a little help just dont go overboard.
Get a good 4 wheel alignment..being an autocrosser you probably already know that. |
(Post 1595969364)
(Post 1595969364)
For the rest thank you for the information, I have had a bunch of C4 Corvettes and have lowered every one of them I am a competitive autocrosser and lowering helps make them fast I thought since the ZR1 is a bit of a special car I would try to lower it the right way. Thanks Dan Teach me master:smash: How many have you had? How have you lowered them? |
