Hood ventilation options?
Though I'd not want to really mangle the hood or buy an aftermarket one... Has anyone put Trans-Am Firehawk style heat-extractors on their hood for forced-induction assistance.
I suspect "throwing snow" meth would be the way to go, however, but I'm looking for idle solutions. |
Vented hood does help with heat soak but I saw no difference driving down the road aside from maybe a little less lift past 150 mph. From a performance standpoint do the meth....
I know some people, for a cheap way, remove back weather stripping at windshield cowl, and some have spaced hood latches to keep hood slightly raised (does not line up with fenders). I do not know how effective either are....
The late 5th Gen Camaro SS/Z28/ZL1 hood vent fits the curve of a C6 hood surprisingly well if you are willing to cut a hole in the middle of your hood. There is a big thread on here about it with tons of pictures of them installed.
Not my car, but here is a post from someone else with the same setup: LINK |
As said above hood helps with lift, almost nothing for cooling or power.
Originally Posted by mikecronis
(Post 1596072663)
I suspect "throwing snow" meth would be the way to go, however, but I'm looking for idle solutions. https://cimg1.ibsrv.net/gimg/www.cor...d010dd19f.jpegVent that fills ZR1 window cut into stock hood |
Originally Posted by Blue by U
(Post 1596074564)
https://cimg2.ibsrv.net/gimg/www.cor...a3e9a04458.jpg
Originally Posted by chpmnsws6
(Post 1596083722)
Worst place to put it. That's a very high pressure area and will slow air through the coolers. Putting vents right after the coolers on the hood is the best option. Forwarned: your engine bay will get dirtier quicker with good vents as the road debris gets pulled up.
that looks pretty natural there, i dig it
The TrackSpec vents are pretty nice. I just got mine this week.
Following: I'm interested in installing the TrackSpec or similar vents.
The only reason I want to do so, however, is to help reduce engine temps while pushing it hard during road racing. I already have meth, so if this won't help..then I'd rather not cut into the hood. |
Originally Posted by ESSFO
(Post 1596787950)
(Post 1596787950)
Originally Posted by itomh
https://cimg9.ibsrv.net/gimg/www.cor...7a3c77bcfd.jpg
https://cimg8.ibsrv.net/gimg/www.cor...20893ea0e4.jpg |
Originally Posted by Sergio7
(Post 1596840994)
Woah! Where did you get those side vents!?
Everything you need to know about where I got them, brackets, mounting with plenty of pictures is in the below link. https://www.corvetteforum.com/forums...placement.html https://cimg7.ibsrv.net/gimg/www.cor...7d758ec432.jpg |
https://cimg7.ibsrv.net/gimg/www.cor...0efab72dc0.jpg
https://cimg2.ibsrv.net/gimg/www.cor...9a12d1cdf6.pngWhy not both meth and vents https://cimg3.ibsrv.net/gimg/www.cor...fe70f66cef.pngSquare stainless aircraft mesh painted transparent black approx 4 3/4 x 10 1/4 long openings. |
(Post 1596773525)
https://cimg8.ibsrv.net/gimg/www.cor...20893ea0e4.jpg id like to see this in person, maybe we can meet up this summer once weather breaks looks great!! |
Originally Posted by ~STOLEN~
(Post 1596870122)
looks great!! |
