1998 to 2002 ecm conversion help
Okay I have converted the ecm in my 1998 to a 2002 ecm with only one problem, the fuel gauge. With the setting for the 1998 fuel system the gauge reads dead empty with a full tank. when I change all fuel system settings to 2002 the gauge works but only reads 3\4 full with a full tank.where do i need to look to get the gauge to work right with the 2002 ecm? I'm tuning with HP tuners.
Okay a tuner in my area told me i need to cut a wire on the secondary tank sending unit but didn't remember which one. has anyone on here done the this before?
Before I started cutting wires I'd try to find a schematic for both and I would find the voltage values each computer is looking for to present to the gauge. Bill Curley would be my go to guy if I were you. Good luck and Merry Christmas!
Does anyone know where i can find wiring schematic's for 1998 and 2002 fuel sending units. I am having no luck on the web finding them.
2 Attachment(s)
Originally Posted by gearheadib
(Post 1596184111)
Cheers, Goose |
Originally Posted by 69
(Post 1596188143)
Here ya go.
Cheers, Goose |
(Post 1596129387)
https://www.corvetteforum.com/forums...-a-98-pcm.html I found the link to that topic in here: https://www.corvetteforum.com/forums...orvette-3.html I google searched the forum using: 0411 ecu 97-98 site:www.corvetteforum.com It has been done and there are topics out there, digging it up may require getting creative with Google. |
Originally Posted by 93Polo
(Post 1596199120)
Post 10 maybe what they are referring to:
(Post 1596211417)
thank you. I cut the wire at pin "A" on the right sending unit and that was it... works great now.
[QUOTE=93Polo;1596224115]:cool: More forced induction guys have done the ECU swap. If you need more help you may try starting a topic in the Forced Induction section. :cheers:[/Q
Thanks for the advice, but i found what i needed right here.:rock: |
