Engine Failure
I have a 2014 corvette with 30k miles and a LIngenfelter 700hp package. A lifter failed, was subsequently ground down by the cam and metal shavings circulated throughout the engine. I need to replace the block, piston, crank, etc. GM won’t warranty the problem because the computer seatings were changed to accommodate the after market parts. Anyone know where I can get OEM parts at a discount? Thanks
Search is your friend :yesnod:
Piston search: https://www.corvetteforum.com/forums...rchid=67801499 Crank search: https://www.corvetteforum.com/forums...rchid=67801544 Best discounts I found on new: https://www.generalmotorspartsonline...at/engine-scat |
Originally Posted by racehorse00
(Post 1596123412)
:cheers: |
Originally Posted by fsvoboda
(Post 1596123494)
Talk to Lingenfelter. Don't they have a warranty?
:cheers: |
Huh ?
(Post 1596124835)
They do but don’t warrant OEM parts. Thanks
This seems rediculious. Huh... 30 K is not a lot of miles, how much did you beat the shit out of this. Kudos to you for driving it!😂😂
I'm confused too. Does Lingenfelter use stock lifters for a 700 HP build? If so, then it's not surprising they failed. When I build my 650 HP BBF for my Cobra, every part was upgraded/strengthened.
Originally Posted by red62vette
(Post 1596125360)
(Post 1596125360)
(Post 1596125808)
LIngenfelter told me they use OEM lifters for their 1000hp package
OP have you got a ballpark figure for the cost of the parts plus labor? I see LT1 crate engines for 10k online. Just a thought that you could plug and play a zero mile motor and then put the Lingenfelter parts back on. Hope you get her back together soon! :cheers: |
If that is the way Lingenfelter handles their warranty, I think we should all stay away from them as suppliers.
Sorry to hear about the engine failure. That really sucks, especially with no warranty coverage. Best of luck finding a new engine and all the parts you need.
Sorry about your luck.
Hope you can push Lingenfelter harder on this, they should at least be pitching in. |
Originally Posted by ramler
(Post 1596126147)
if that is the way lingenfelter handles their warranty, i think we should all stay away from them as suppliers.
Many times we go to these "big name vendors, ie. Calloway, Eddlebrock, Lingenfelter" because they offer the warranty. If they're going to deny warranty because engine has "factory parts", what a bunch of bullsh*t. |
I wouldn't put all aftermarket engine builders who offer a warranty with their product in the same category; we have heard/read nothing that says they do the same as Lingenfelter.
Originally Posted by AORoads
(Post 1596129399)
Just like most things in life "Buyer beware" but a claim that warranty approved coverage seems lost on some aftermarket dealers. :thumbs:
(Post 1596129399)
Originally Posted by Martman C7
(Post 1596127888)
+1000
Many times we go to these "big name vendors, ie. Calloway, Eddlebrock, Lingenfelter" because they offer the warranty. If they're going to deny warranty because engine has "factory parts", what a bunch of bullsh*t. :cheers: |
Here is how Callaway's warranty works:
What to do if your Callaway has a problem. Callaway engineers have performed extensive vehicle testing and validation in order to ensure that your Callaway provides reliable service. However, if a problem should arise that requires technical attention, please follow this procedure: Contact your closest Callaway-Authorized GM Dealer and discuss the symptoms with the Dealer’s Service Manager. If required, make an appointment with the Dealer to bring the car in, or have the car transported to the Dealer, per the Dealer’s recommendation. If there is no Callaway-Authorized Dealer nearby, you may follow this procedure with your closest Buick, Chevrolet, GMC or Cadillac Dealer. If you bring your car to a Dealership that is not a Callaway-Authorized Dealer, please be sure to tell the Service Manager to contact Callaway Technical Service upon arrival, prior to performing any vehicle diagnostics. This will facilitate quicker, more satisfactory repair. For accurate, timely updates, always contact the Dealership regarding the status of your Callaway’s repair, not Callaway. When your Callaway was assembled, Callaway affixed a label to its under-dash diagnostic port in order to prevent the dealer from recalibrating or updating the ECM (engine control module) without contacting Callaway first. If the Dealer informs you that they plan to re-flash or update the ECM calibration, please remind him to contact Callaway first to arrange for re-installation of the Callaway calibration. Otherwise, “Service Engine Soon” lights will be triggered and poor engine performance will result. Do not pay the Dealer for any Callaway-associated warranty repairs. Callaway policy is to reimburse the Dealer directly for all applicable warranty-associated parts and labor. Callaway 3 year / 36,000 mile Limited Warranty Standard Equipment on all new Callaway cars and trucks Unlike other aftermarket warranties, Callaway provides a comprehensive warranty program that works in tandem with General Motors’ OEM warranties, providing seamless coverage of both Callaway and GM installed components during the term of GM’s Bumper-to-Bumper Warranty. In the rare occasion that a Callaway car or truck requires attention by a GM dealer to address a warranty-related problem, GM and Callaway work together to return the vehicle to its owner as soon as possible. For 36 months or 36,000 miles from the vehicle in-service date or mileage (whichever comes first) Callaway assists the dealer to conduct a timely diagnosis of the problem. Callaway will then supply any required Callaway replacement parts and technical support, and reimburse the dealer for the dealership’s labor cost. Plus, if failure of a Callaway component should result in damage to covered GM powertrain parts, Callaway will also reimburse the dealer for those parts and labor as well. |
