HP Tuners VCM Suite + $40 or $80 Gift Certificate-Free Shipping!
HP Tuners VCM Suite + $40 or $80 TPS Gift Certificate-Free Shipping! https://cimg5.ibsrv.net/gimg/www.cor...0542f1e3a0.jpg Click here to purchase! BUY ANY HP TUNERS VCM SUITE & GET A FREE TPS GIFT CERTIFICATE! -Get a $40 TPS Gift Certificate with a VCM Suite Standard Edition purchase* -Get a $80 TPS Gift Certificate with a VCM Suite Professional Edition purchase* *Gift Certificate must be used with a future purchase The VCM Editor utility is a comprehensive VCM/PCM programmer and parameter editor. VCM Editors Flash utility allows the user to read the VCM/PCM flash memory and save it to a binary file. The Flash utility allows a valid calibration to be written to the VCM/PCM and also incorporates an automatic VCM/PCM recovery capabilities for ultimate protection against any reflashing problems that may be encountered. The VCM Editor also allows modification of the saved binary image. The VCM Editor allows all parameters such as Spark, Fuel, RPM Limits, FAN Temps, Transmission Shift points and pressures, Speedometer settings and many, many more. The editor provides an easy to use graphical interface and many powerful table manipulation capabilities such as copying, scaling and shifting to name a few. So you're probably thinking, what else could there be for a professional tuner? Well, read on... The VCM Suite has certain features that a professional tuner may find more useful. It includes some of the following extra capabilities. VCM Editors Flash utility allows not just calibration reflashing and automated recovery, but entire VCM/PCM image reflashing. This means that you are free to make any operating system or calibration level modifications and flash those to the VCM/PCM. This has many uses for the advanced enthusiast, serious tuner or engine swap shop, allowing complete control over the VCM/PCM software environment. The VCM Editor also allows for increased vehicle support for tuners, and also access to extra VCM/PCM operating system code modifcations. Tuners also have the option to modify VIN's, a useful feature for mail order VCM's. Security. Protect your tunes with Tunerlock. Only you have the ability to read and write to VCM/PCM's that you have Tunerlocked. Prevent unwanted access to your hard work. The VCM Scanner utility is a fully featured OBDII scanning and diagnostic tool. It allows viewing, charting and logging of diagnostic data in real time via the vehicle OBDII diagnostic data port. It also allows viewing of vehicle Diagnostic Trouble Codes (DTC's) and other vehicle information. Built in VCM controls also supported. Command fans, closed loop, gear select, timing, air fuel ratio and more real time! No editor package can be considered complete without comprehensive scan tool capabilities. VCM Suite is the complete package. These components combine to make VCM Suite the most feature rich, powerful and comprehensive VCM/PCM reprogramming and diagnostics package available on the market today. In addition, our attractive make/model/year based licensing structure makes VCM Suite a clear leader in value for money. What does the MPVI Pro interface allow me to do over the Standard Version? With our Pro interface, you can integrate 0-5v signals from various sensors such as EGT, Wide Band, fuel pressure and others right into our scanner. You will have real time data from those sensors right next to your standard scan tool data such as TPS, RPM, MPH, etc. Our MPVI Pro interface also has black box data datalogging for select vehicles of up to 1hr 30mins built in. What this means is you are able to scan your vehicle without the use of a laptop using the interfaces record button. You can then take the interface into your home to transfer the log contents from the interface to the computer. If you have an MPVI Pro it will require no hardware modification. Also note that VCM Scanner comes with both interfaces regardless as it is part of our VCM Suite package. Can I buy a wide band sensor and simply plug it in? No. You need a wide band kit that supplies a 0-5v output. You will plug the output from your wide band controller into our interface. Is a Wideband Sensor & Controller included with the MPVI Pro? No. But you can purchase one from HPTuners we sell the DynoJet 15-7003 and the NGK AFR500 #SNSR-00990-2-2 How many external devices can I have with the MPVI Pro? We have provisions for 4 external devices that use a 0-5v output signal. Does the Standard MPVI come with the scanner too? Yes it comes with the hardware, the same scanner the pro comes with & the same editor package as the pro comes with. Does the Standard MPVI come with the same amount of credits as the Pro MPVI? Yes, both the Standard & Pro Version come with 8 credits. |
1 Attachment(s)
HP Tuners is a Great Christmas Present in stock ready to ship!! BUY ANY HP TUNERS VCM SUITE & GET A FREE TPS GIFT CERTIFICATE! -Get a $40 TPS Gift Certificate with a VCM Suite Standard Edition purchase* -Get a $80 TPS Gift Certificate with a VCM Suite Professional Edition purchase* *Gift Certificate must be used with a future purchase |
