FX# actuating gear
Need a new gear for my front shock on my 92, if anyone has one PM me, Lee was nice enough to direct me to Ecklers for some, they look better and have better coating than stock, are they better???? Thanks guys
for a used cup that goes on the top of the shock. |
Originally Posted by Z51JEFF
(Post 1596294575)
I’d only check with this place as a last resort,guy wanted $40
thanks guys, I got two new ones.
So a (slightly) off topic question...
How do you "test" to see if your FX3 system is working? I've never worried about mine (just keeping it on Touring) but this post has me thinking. Thanks! |
Originally Posted by billschroeder5842
(Post 1596319334)
How do you "test" to see if your FX3 system is working? I've never worried about mine (just keeping it on Touring) but this post has me thinking. Thanks! When the ignition key is turned, the system will do a check to be sure it is working properly. The service ride control light should come on momentarily and then go out if all is well. If the light stays on then the system most likely has problems. See Tires and Selective Ride Control |
