Nick williams 102mm throttle body on sale and in stock at juiced!!!
Nick Williams Performance drive-by-wire throttle bodies are CNC precision-machined from billet aluminum to meet the demands for increased airflow on the drive-by-wire LSX performance engines. The 102mm throttle bodies require an aftermarket intake to fit the larger diameter throttle blade. They use a 6-pin late model connector that works with late model wiring harnesses. Tuning is required for installation; and the Nick Williams Performance drive-by-wire throttle bodies come complete with stepper motor and electronics installed—no need to disassemble your factory throttle body. https://cimg9.ibsrv.net/gimg/www.cor...f715ff0c79.png 102MM DRIVE-BY-WIRE LS THROTTLE BODY 102MM DRIVE-BY-WIRE BOOSTED LS THROTTLE BODY (FOR CARS MAKING SERIOUS BOOST) |
You can't make power without air.
A must for big power builds
The factory throttle body is a major bottle neck
Great option for big power
If you are adding boost the factory 75MM throttle body won't cut it.
When porting won't cut it
Perfect match with an aftermarket intake.
Great mod
A must with aftermarket intakes
These NW throttle bodies are top quality
75mm vs 102mm It's a big jump
In stock and ready to ship
Nw tb
Great quality
